[petsc-dev] -pc_asm_blocks
Jed Brown jed at 59A2.org
Mon Jan 18 18:07:14 CST 2010
I just pushed some fixes for the issue in this thread.  You will
typically notice somewhat different performance with multiple blocks per
process because a different partition is used.  In some special cases,
you can reproduce the partition through appropriate use of
-mat_partitioning_type.  For example
  $ mpirun -n 7 ./ex2 -pc_type asm -pc_asm_blocks 7
  Norm of error 0.000458307 iterations 7
  $ mpirun -n 1 ./ex2 -pc_type asm -pc_asm_blocks 7         # parmetis for me
  Norm of error 0.000180024 iterations 8
  $ mpirun -n 1 ./ex2 -pc_type asm -pc_asm_blocks 7 -mat_partitioning_type square
Jed
