[petsc-dev] -pc_asm_blocks
Mon Jan 18 07:58:46 CST 2010
On Mon, Jan 18, 2010 at 7:53 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 18, 2010 at 7:45 AM, Jed Brown <jed at 59a2.org> wrote:
>> I thought this used to work:
>> $ cd petsc/src/ksp/ksp/examples/tutorials/
>> $ ./ex2 -pc_type asm -pc_asm_blocks 2
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data!
>> [0]PETSC ERROR: Specified ASM subdomain sizes were invalid: 112 != 56!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> c48026146083ef288c8218540e6f61b678c1c226 HG Date: Sun Jan 17 17:16:57 2010
>> +0100
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./ex2 on a ompi named kunyang by jed Mon Jan 18 14:39:15
>> 2010
>> [0]PETSC ERROR: Libraries linked from /home/jed/petsc/ompi/lib
>> [0]PETSC ERROR: Configure run at Sun Jan 17 17:20:32 2010
>> [0]PETSC ERROR: Configure options --with-zoltan-dir=/usr --download-ml
>> --with-blas-lapack-dir=/usr --download-blacs --download-chaco
>> --with-hdf5-dir=/usr --download-mumps --download-superlu_dist
>> --download-spooles --download-sundials --download-hypre --with-c2html
>> --with-mpi-dir=/usr --with-umfpack-dir=/usr --with-parmetis-dir=/usr
>> --download-scalapack --with-lgrind --with-shared --with-sowing
>> -PETSC_ARCH=ompi --download-superlu --download-spai
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: PCSetUp_ASM() line 239 in src/ksp/pc/impls/asm/asm.c
>> [0]PETSC ERROR: PCSetUp() line 795 in src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: main() line 196 in src/ksp/ksp/examples/tutorials/ex2.c
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 77.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Looking at the loop that is generating this inconsistency, osm->is_local
>> is NULL, so we take the second branch for each block:
>>      if (osm->is_local) {
>>      } else {
>>        ierr = VecGetLocalSize(vec,&m_local);CHKERRQ(ierr);
>>        osm->y_local[i] = osm->y[i];
>>        ierr = PetscObjectReference((PetscObject) osm->y[i]);CHKERRQ(ierr);
>>        osm->prolongation[i] = osm->restriction[i];
>> osm->restriction[i]);CHKERRQ(ierr);
>> But vec is everything owned by that process so m_local is too big unless
>> there is only one subdomain.  What was this code supposed to be doing?
> I had to change ASM back in July? to get multiple overlapping blocks on a
> given parallel subdomain.
> Why?
>   We used a particularly simple mechanism to implement RASM, namely
> dropping off-process values.
> That does not work when you have 2+ domains on 1 process.
>   I needed this functionality for our RBF preconditioner
> How?
>   I added another IS that gave the local part of each block, since we
> already know the blocks themselves.
> It is taking the right branch here since no extra IS is specified.
> What is wrong?
>   I do not understand the comment. The local size should be right.
Okay, I just tried it and I understand the problem: This never really
worked. RASM was not doing the proper thing.
Now it does, but we need to correct the code to produce is_local
automatically with this argument.
  Matt
>   Matt
>> Jed
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100118/67b23841/attachment.html>
