[petsc-dev] PETSC_USE_SOCKET_VIEWER macro - controlled by configure or not
Tue Jan 12 19:37:41 CST 2010
   If the computer system (like some of the Cray's) don't provide UNIX
socket support then you cannot use the PETSc socket routines.
    Barry
On Jan 12, 2010, at 6:08 PM, Kevin.Buckley at ecs.vuw.ac.nz wrote:
> Hi there,
> I am tying to help a researcher here build his application against
> a PETSc (3.0.0 p9) installtion at another site that seems to have
> undefined references to:
> PETSC_VIEWER_SOCKET_
> in it.
> Looking at my local installtion, the undefined refs are seemingly
> fixed up in    libpetsc.a
> send.o:
>         U MPI_Attr_get
>         U MPI_Attr_put
>         U MPI_Comm_rank
>         U MPI_Keyval_create
>         U OMPI_C_MPI_NULL_COPY_FN
>         U OMPI_C_MPI_NULL_DELETE_FN
> 00001a4a T PETSC_VIEWER_SOCKET_
> however on the implementation that the researcher is looking to build
> against, that "T PETSC_VIEWER_SOCKET_" is not there.
> I noticed in the example config script for the Cray that there's a
> notification that:
> # After running configure, remove the following flags from petscconf.h
> # PETSC_HAVE_SYS_PROCFS_H
> # PETSC_HAVE_DLFCN_H
> ###### On Cray XT4 the following additional flags need removal
> # PETSC_USE_SOCKET_VIEWER
> # PETSC_HAVE_GETPWUID
> and think that this might be the problem here.
> Am I right in thinking that PETSC_USE_SOCKET_VIEWER, the macro
> that determines whether PETSc compiles in any socket viewer code
> is not something that gets turned /onoff automatically by any
> option to configure  ?
> Kevin
> Kevin M. Buckley                                  Room:  CO327
> School of Engineering and                         Phone: +64 4 463
> 5971
> Computer Science
> Victoria University of Wellington
> New Zealand
