[petsc-dev] PETSC_USE_SOCKET_VIEWER macro - controlled by configure or not
Kevin.Buckley at ecs.vuw.ac.nz Kevin.Buckley at ecs.vuw.ac.nz
Tue Jan 12 18:08:33 CST 2010
Hi there,
I am tying to help a researcher here build his application against
a PETSc (3.0.0 p9) installtion at another site that seems to have
undefined references to:
PETSC_VIEWER_SOCKET_
in it.
Looking at my local installtion, the undefined refs are seemingly
fixed up in    libpetsc.a
send.o:
         U MPI_Attr_get
         U MPI_Attr_put
         U MPI_Comm_rank
         U MPI_Keyval_create
         U OMPI_C_MPI_NULL_COPY_FN
         U OMPI_C_MPI_NULL_DELETE_FN
00001a4a T PETSC_VIEWER_SOCKET_
however on the implementation that the researcher is looking to build
against, that "T PETSC_VIEWER_SOCKET_" is not there.
I noticed in the example config script for the Cray that there's a
notification that:
# After running configure, remove the following flags from petscconf.h
# PETSC_HAVE_SYS_PROCFS_H
# PETSC_HAVE_DLFCN_H
###### On Cray XT4 the following additional flags need removal ########
# PETSC_USE_SOCKET_VIEWER
# PETSC_HAVE_GETPWUID
and think that this might be the problem here.
Am I right in thinking that PETSC_USE_SOCKET_VIEWER, the macro
that determines whether PETSc compiles in any socket viewer code
is not something that gets turned /onoff automatically by any
option to configure  ?
Kevin
Kevin M. Buckley                                  Room:  CO327
School of Engineering and                         Phone: +64 4 463 5971
 Computer Science
Victoria University of Wellington
New Zealand
