[petsc-dev] improvement to ./configure
Richard Tran Mills rmills at climate.ornl.gov
Fri Jan 8 16:28:13 CST 2010
Hi Barry,
I'm one of those folks who likes to call configure from a Python script.  Here
it is:
#!/usr/bin/env python
configure_options = [
   '--with-cc=gcc',
   '--with-fc=gfortran',
   '--with-cxx=g++',
   'COPTFLAGS=-g',
   'FOPTFLAGS=-g',
   'CXXOPTFLAGS=-g'
#  '--with-mpi-include=/home/petsc/soft/linux-rh73/mpich-1.2.4/include',
'--with-mpi-lib=[/home/petsc/soft/linux-rh73/mpich-1.2.4/lib/libpmpich.a,libmpich.a,libpmpich.a]',
if __name__ == '__main__':
   import sys,os
   sys.path.insert(0,os.path.abspath('config'))
   import configure
   configure.petsc_configure(configure_options)
The name of the script is 'ubuntu-gnu_g.py'.  Changing it to 'ubuntu-gnu-g.py'
makes this problem go away.
--Richard
Barry Smith wrote:
>   Please cut and paste exactly what command you run. The commands to
> ./configure usually have --xxxx they don't usually consist of a filename.
>    Barry
> On Jan 8, 2010, at 4:13 PM, Richard Tran Mills wrote:
>> Matt,
>> I now get something like the following when executing a configuration
>> script with a '_' in it:
>> Traceback (most recent call last):
>>  File "config/ubuntu-gnu_g.py", line 18, in <module>
>>  File "/home/rmills/proj/petsc-dev/config/configure.py", line 150, in
>> petsc_configure
>>    check_for_option_mistakes(sys.argv)
>>  File "/home/rmills/proj/petsc-dev/config/configure.py", line 33, in
>>    raise ValueError('The option '+name+' should probably be
>> '+name.replace('_', '-'));
>> ValueError: The option config/ubuntu-gnu_g.py should probably be
>> config/ubuntu-gnu-g.py
>> It seems like not allowing '_' characters in these filenames is an
>> unintended consequence.
>> --Richard
>> Matthew Knepley wrote:
>>> Pushed something. Let me know if this is what you had in mind.
>>>  Matt
>>> On Mon, Jan 4, 2010 at 7:52 AM, Barry Smith <bsmith at mcs.anl.gov
>>> <mailto:bsmith at mcs.anl.gov>> wrote:
>>>     Matt,
>>>      Thanks!
>>>       Barry
>>>    On Jan 4, 2010, at 12:20 AM, Matthew Knepley wrote:
>>>        I can try to put something in.
>>>         Matt
>>>        On Sun, Jan 3, 2010 at 7:16 PM, Barry Smith <bsmith at mcs.anl.gov
>>>         Matt,
>>>         It would be nice when some user types --xxxx-yyyyyy_zzzz and
>>>        they meant --xxxx-yyyyyy-zzzz it would give them a nice error
>>>        message. This is made difficult by the fact that superlu_dist
>>>        name as an underscore in it. Are there other special cases?
>>>         Could we have BuildSystem barf with helpful error message
>>>        whenever someone puts an _ instead of - except when allowed like
>>>        superlu_dist?
>>>         We semi-regularly waste time with petsc-maint messages of
>>>        people who cannot distinguish _ from -
>>>          Barry
>>>        --         What most experimenters take for granted before
>>> they begin their
>>>        experiments is infinitely more interesting than any results to
>>>        which their experiments lead.
>>>        -- Norbert Wiener
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
>> Richard Tran Mills, Ph.D.            |   E-mail: rmills at climate.ornl.gov
>> Computational Scientist              |   Phone:  (865) 241-3198
>> Computational Earth Sciences Group   |   Fax:    (865) 574-0405
>> Oak Ridge National Laboratory        |   http://climate.ornl.gov/~rmills
