[petsc-dev] Old docs for petsc-dev
Jed Brown jed at 59A2.org
Fri Jan 8 10:16:13 CST 2010
On Fri, 8 Jan 2010 09:58:11 -0600 (CST), Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 8 Jan 2010, Jed Brown wrote:
> > In particular, I would expect this changelist to include dev.html since
> > the other stuff at snapshots/petsc-dev/docs are current.
> >   http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/changes/index.html
> Hmm. this was ment to list the releases and the dates. dev.html is
> linked from the following locations
> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/index.html
Thanks.  I was confused by the directory layout because if I read the
man pages at
they are all from the release.  I can browse development docs at
but the changes at
are from the release, and in particular
  http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/changes/dev.html
does not exist.
Jed
