[petsc-dev] NetBSD port
Kevin.Buckley at ecs.vuw.ac.nz Kevin.Buckley at ecs.vuw.ac.nz
Thu Jan 7 16:59:51 CST 2010
> Hopefuly, of course, it won't fail because I'll unearth problems with
> OpenMPI!
> There are a couple of things I want to try with regard to the NetBSD
> port of OpenMPI, actually things that I had meant to tidy up in the
> wake of the developments on that NetBSD port over the last few weeks.
> I do not actually think they affect this issue but you never know
> and if I remove them from the equation, then they certainly can't.
> Thanks for the PETSc insight,
> Kevin
Can't recall if I followed up on this in the last few days before
the festive season, but there was an issue with OpenMPI upon the
NetBSD platform.
We came up with a temporary workaround - basically, a different route
through the network interface evaluation code - and have since seen
the target application running, albeit not as well as we expected.
That's another issue though, a thread realting to which I'll be
starting soon!
Kevin M. Buckley                                  Room:  CO327
School of Engineering and                         Phone: +64 4 463 5971
 Computer Science
Victoria University of Wellington
New Zealand
