[petsc-dev] DMMG without libpetscsnes?
Thu Jan 7 10:27:38 CST 2010
On Jan 7, 2010, at 10:10 AM, Matthew Knepley wrote:
> On Thu, Jan 7, 2010 at 9:12 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>  Let's get this dang PETSc release out the door and then fix up the
> solvers by properly merging DMMG into KSP and SNES
> 1) What do we need for the release?
> 2) It seems that what you want is the Builder paradigm for PC (MG),
> KSP, SNES where builders take a DMMG, or the
>     builder is part of DMMG. Does this seem right to you?
   Not exactly. In the same way that in PETSc a Mat is also a factory
for matrices I want KSP/PC to be "builders" for themselves. So there
is no DMMG at all, its "builder" functionality is properly put into
KSP/PC.
    Barry
>    Matt
>   Barry
> On Jan 7, 2010, at 8:34 AM, Barry Smith wrote:
>  DMMG used to be split up (as you note from the stale comment). I
> ended up merging them because it wasn't worth the effort and
> complication to keep them in two parts.
>  I would not like to see them split up again. Rather I would like to
> see the linear part of DMMG put into KSP/PC/DMMG somehow (not
> exactly sure how) so it can be properly nested and composed just
> like other preconditioners. I'm sure you are doing something
> slightly cumbersome now to put your DMMG inside the Schur
> fieldsplit. For linear DMMG I think the design is all wrong as it is
> now.
>  Here is how I see it: DMMG's job is to "fill up" the appropriate
> fields in the KSP, PC, MG objects, then when solving those fields
> are used. I would like (somehow) the KSP, PC, MG objects to have the
> mechanism that you can provide a DM to them and they can then "fill
> up" their fields. But it is important we get this right and
> compossible so I have hesitated to ever try it. The starting point
> might be having an (optional) KSPSetDM() that would propagate the DM
> into the PC and subPCs and subsubPCs etc where they would be used to
> fill the slots if provided.
>  Going to the basic design motto of PETSc, "only a single way to do
> each action", it is obvious that DMMG is totally wrong since there
> is a KSPSolve() and a DMMGSolve()! Someday I want this fixed.
>  Barry
> On Jan 7, 2010, at 7:13 AM, Jed Brown wrote:
> I'm using a DMMG inside of a Schur fieldsplit, but I have to create it
> before PCSetUp because the hierarchy is generated by refinement.  It
> doesn't make sense to call DMMGSetKSP before PCSetUp because that
> matrix
> would be worthless, but I want to be able to view the DMMG even if
> only
> to inspect the hierarchy.  While putting in a check for NULL snes in
> DMMGView, I noticed these lines in damg.c
>    /* use of PetscObjectView() means we do not have to link with
> libpetscsnes if SNES is not being used */
>    ierr = PetscObjectView((PetscObject)dmmg[nlevels-1]-
> >snes,viewer);CHKERRQ(ierr);
> This appears to be stale because damg.c *is* part of libpetscsnes.  In
> fact, all of damg.c can be moved to ksp/ksp/utils after
> s.PETSCSNES_DLLEXPORT.PETSCKSP_DLLEXPORT., but DMMGSetUp (in
> damgsnes.c)
> currently has a real dependency on SNES due to SNESGetKSP's special
> treatment of DMComposite+PCFieldSplit.
> Is there value in having DMMG usable in the absence of libpetscsnes
> (i.e. DMMGSetUp's dependency on SNES will be broken)?
> Jed
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
