[petsc-dev] DMMG without libpetscsnes?
Thu Jan 7 08:34:40 CST 2010
   DMMG used to be split up (as you note from the stale comment). I
ended up merging them because it wasn't worth the effort and
complication to keep them in two parts.
   I would not like to see them split up again. Rather I would like to
see the linear part of DMMG put into KSP/PC/DMMG somehow (not exactly
sure how) so it can be properly nested and composed just like other
preconditioners. I'm sure you are doing something slightly cumbersome
now to put your DMMG inside the Schur fieldsplit. For linear DMMG I
think the design is all wrong as it is now.
    Here is how I see it: DMMG's job is to "fill up" the appropriate
fields in the KSP, PC, MG objects, then when solving those fields are
used. I would like (somehow) the KSP, PC, MG objects to have the
mechanism that you can provide a DM to them and they can then "fill
up" their fields. But it is important we get this right and
compossible so I have hesitated to ever try it. The starting point
might be having an (optional) KSPSetDM() that would propagate the DM
into the PC and subPCs and subsubPCs etc where they would be used to
fill the slots if provided.
   Going to the basic design motto of PETSc, "only a single way to do
each action", it is obvious that DMMG is totally wrong since there is
a KSPSolve() and a DMMGSolve()! Someday I want this fixed.
    Barry
On Jan 7, 2010, at 7:13 AM, Jed Brown wrote:
> I'm using a DMMG inside of a Schur fieldsplit, but I have to create it
> before PCSetUp because the hierarchy is generated by refinement.  It
> doesn't make sense to call DMMGSetKSP before PCSetUp because that
> matrix
> would be worthless, but I want to be able to view the DMMG even if
> only
> to inspect the hierarchy.  While putting in a check for NULL snes in
> DMMGView, I noticed these lines in damg.c
>      /* use of PetscObjectView() means we do not have to link with
> libpetscsnes if SNES is not being used */
>      ierr = PetscObjectView((PetscObject)dmmg[nlevels-1]-
> >snes,viewer);CHKERRQ(ierr);
> This appears to be stale because damg.c *is* part of libpetscsnes.  In
> fact, all of damg.c can be moved to ksp/ksp/utils after
> s.PETSCSNES_DLLEXPORT.PETSCKSP_DLLEXPORT., but DMMGSetUp (in
> damgsnes.c)
> currently has a real dependency on SNES due to SNESGetKSP's special
> treatment of DMComposite+PCFieldSplit.
> Is there value in having DMMG usable in the absence of libpetscsnes
> (i.e. DMMGSetUp's dependency on SNES will be broken)?
> Jed
