[petsc-dev] preparing for PETSc release 3.0.1
Sat Feb 27 00:44:44 CST 2010
Second issue:
* Its looking for every source file - and attempts to compile it?
  conftest.c, ex15.c etc.. What does it do to control what sources
  should be compiled - and what not? [i.e do we specify
  sourcefile:library dependency?]
Satish
asterix:/home/balay/tmp/petsc-dev>./config/builder.py
  Loaded configure to cache: size 210163
Processing /home/balay/tmp/petsc-dev
Entering /home/balay/tmp/petsc-dev
Compiling C files ['conftest.c']
/home/balay/soft/linux64/mpich2-1.1/bin/mpicc -c -I/home/balay/tmp/petsc-dev/asterix64/include -I/home/balay/tmp/petsc-dev/include -I/home/balay/soft/linux64/mpich2-1.1/include  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3     -D__SDIR__='""' conftest.c
Archiving files ['conftest.o'] into libpetscfake
/usr/bin/ar cr /home/balay/tmp/petsc-dev/asterix64/lib/libpetscfake.a conftest.o
Processing /home/balay/tmp/petsc-dev/src
Entering /home/balay/tmp/petsc-dev/src
Rejecting /home/balay/tmp/petsc-dev/src/tops because package 'PETSC_HAVE_BABEL' is not installed
Processing /home/balay/tmp/petsc-dev/src/contrib
Entering /home/balay/tmp/petsc-dev/src/contrib
Rejecting /home/balay/tmp/petsc-dev/src/contrib/blopex because package 'PETSC_HAVE_BLOPEX' is not installed
Processing /home/balay/tmp/petsc-dev/src/contrib/keyes
Entering /home/balay/tmp/petsc-dev/src/contrib/keyes
Compiling C files ['ex15.c']
/home/balay/soft/linux64/mpich2-1.1/bin/mpicc -c -I/home/balay/tmp/petsc-dev/asterix64/include -I/home/balay/tmp/petsc-dev/include -I/home/balay/soft/linux64/mpich2-1.1/include  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3     -D__SDIR__='"/src/contrib/keyes"' ex15.c
Archiving files ['ex15.o'] into libpetscfake
/usr/bin/ar cr /home/balay/tmp/petsc-dev/asterix64/lib/libpetscfake.a ex15.o
On Sat, 27 Feb 2010, Matthew Knepley wrote:
> 1) builder.py --help :)
> 2) You give it a root directory to start (default is PETSC_DIR) and it does
> recursive make
> 3) The current target is libpetscfake.a so I never accidentally blow away my
> install
>    Matt
> On Sat, Feb 27, 2010 at 4:44 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Matt,
> > Any instructions on how to use/test builder.py?
> > Satish
> > On Fri, 26 Feb 2010, Matthew Knepley wrote:
> > > What do people think about builder.py for the release? I really really
> > want
> > > a version
> > > I can use in China.
> > >    Matt
> > > On Thu, Feb 25, 2010 at 2:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > >  I'd like to get the next PETSc release out very soon (so we can start
> > > > ripping petsc-dev apart and making it way cooler :-). Please send in
> > any
> > > > outstanding bug reports and test your applications to make sure the
> > code is
> > > > in good shape.
> > > >   Thanks
> > > >    Barry
