[petsc-dev] dealing with MPIUNi
Fri Feb 26 14:20:40 CST 2010
   Satish,
    Ok I will expose the -Impiuni/ so that external packages can use
the MPI uni directly. Please let me know if problems arise.
    Barry
On Feb 26, 2010, at 2:01 PM, Satish Balay wrote:
> I should have included facets-devel in this discussion. Will cc
> facets-devel list now [there are likely to be e-mail bounces due to
> this - will handle the bounces on petsc-dev]
> The discussion is at:
> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002200.html
> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002270.html
> The one usage I know off - is petsc+mpiuni is from uedge. I'm guessing
> there are other usages from facets [I don't really know these other
> usages]
> Based on the previous discussions on facets-devel list, I was
> advocating the following: when having sequential builds with multiple
> packages - that have their own internal seqmpi switch [with normal mpi
> code]:
> - the best thing to do is always use a proper mpi impl even for
>   sequential builds - and make every package use this impl[ with
>   perhaps an error message when parallel run is attempted]
> - if proper mpi must to be avoided - then one way to minise conflicts
>  is use seq-mpi from only one package - and have others use this
>  aswell. However this does not work with all packages [as there are
>  some packages that do need MPI - like hypre etc..].
> So currently mpiuni is being used as the common seq-mpi [from uedge,
> and perhaps other codes]
> Wrt uedge I'm yet to check how the current changes might affect
> it. [currently uedge buildsystem does not work with petsc-dev [due to
> the makefile changes]. will check on this later.
> On Fri, 26 Feb 2010, Barry Smith wrote:
>> If we switch back slightly to the old model in the following way
>> will that
>> resolve the problems with FACETS?
>> 1) expose the mpiuni include directory by adding the mpiuni include
>> path to
>> the list of include search paths
> wrt uedge - the current buildsystem picks up everything from PETSc
> makefiles -
> so the above change should work.
>> 2) DO NOT set PETSC_HAVE_MPI
> uedge does not use this - so this change should be fine.
>> 3) DO NOT have a separate mpiuni library (which doesn't exist with
>> single
>> library anyways).
> since uedge links with petsc+mpi detected from petsc makefiles - this
> should work..
>> Slightly related note: is there any reason not to always #if
>> defined(MPIUNI_AVOID_MPI_NAMESPACE) so that C mpi symbols don't
>> appear in our
>> libraries. Not that this is important but I still like simple clean
>> code
>> without a bunch of confusing if not needed ifdefs.
> Looks like when this flag is defined - the fortran mpiuni symbols are
> also not built.
> satish
>>  Barry
>> On Feb 26, 2010, at 1:00 PM, Barry Smith wrote:
>>> 1)  So FACETS Fortran code includes mpif.h directly AND includes
>>> PETSc
>>> includes in the same file? Can those extra includes just be
>>> removed from
>>> FACETS.
>>> 2)  Some FACES codes, or other packages that FACETS use THAT DO
>>> NOT use
>>> PETSc can/do use PETSc's mpiuni mpif.h?
>>> Are these ONLY conflict with the new MPI unimodel and FACETS or
>>> are there
>>> other conflicts?
>>> Is there any issue with not having a separate libmpiuni.a ?
>>> Barry
>>>>> On Feb 26, 2010, at 11:22 AM, Satish Balay wrote:
>>>>>> I think eliminating mpi.h, mpi.mod etc is not a good change. Its
>>>>>> likely to break users codes.  I suspect it breaks FACETS. [and
>>>>>> perhaps
>>>>>> Flotran]
>>>>> Suspect isn't good enough. HOW does it break FACETS? It won't
>>>>> break
>>>>> pflotran
>>>>> unless they have #include "mpi.h" directly in their code
>>>> Just for this reason [prohibiting using 'mpi.h'/mpif.h from user
>>>> code
>>>> - if one wants --with-mpi=0] the current change is bad
>>>> I've explained the facets/uedge model used below.  I'll check uedge
>>>> usage. I'll have to ask facets folks to check other usages..
>>>>>> With this change we will continue to have MPI symbols [esp from
>>>>>> fortran] in libpetsc.a. So this is not really clean absorbtion of
>>>>>> mpiuni into petsc. And I don't think we can avoid having these
>>>>>> MPI
>>>>>> symbols in -lpetsc.
>>>>> Yes the fake "symbols" are in libpetsc.a but what is wrong with
>>>>> that?
>>>>> What
>>>>> is the disadvantage over having them in libmpiuni.a?
>>>>>> The fact that MPI API symbols exist in libpetsc.a makes PETSc not
>>>>>> really pure plant. Its still a plant/animal - so the goal of
>>>>>> this code
>>>>>> reorganization is still not met.
>>>>> As I said in my previous email; only Matt's plan is perfect.
>>>> My argument is - the change mode is still imperfect - but at the
>>>> cost
>>>> of breaking some user codes. [so its not worth the cost].
>>>>>> [I might not have raised this issue earlier wrt merging mpiuni
>>>>>> completely into petsc - thats my omission sorry about that.]
>>>>>> I suspec the following usage in FACETS/UEDGE will break with this
>>>>>> change:
>>>>>> If you have package-A doing the same type of thing for its
>>>>>> sequential
>>>>>> implementation - it will have its own mpi_comm_size() etc
>>>>>> internally.
>>>>>> With this - mixing package-A with petsc-sequential will cause
>>>>>> duplicate symbol conflict.
>>>>> The fix is to not have any symbols in MPIUNI that are called
>>>>> MPI_xxx
>>>>> This is
>>>>> handled in mpiunis mpi.h with
>>>>> #if defined(MPIUNI_AVOID_MPI_NAMESPACE)
>>>>> we should just ALWAYS avoid the MPI Namespace
>>>>>> The way I'm currently resolving this issue is: Only one package
>>>>>> should
>>>>>> provide [internal] MPI - the other package is compiled with
>>>>>> --with-mpi=enabled.
>>>>>> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is
>>>>>> now
>>>>>> compiled with MPI-ENABLED - but links with PETSc - that provides
>>>>>> MPIUNI - as MPI.
>>>>>> Also due to this - we added more stuff to MPUNI to cover all MPI
>>>>>> symbol usage from FACETS.
>>>>>> So - the previous MPIUNI implementation scheme eventhough
>>>>>> slightly
>>>>>> inconsistant, provided good user interface - with minimal
>>>>>> maintainance
>>>>>> overhead.. Matt's schem makes everything consistant - but with
>>>>>> extra
>>>>>> maintainance overhead.
>>>>> We can certainly go back to the way it was if we need to. But
>>>>> you have
>>>>> not
>>>>> demonstrated that need, you've only speculated.
>>>>> Here is how it should work ok.
>>>>> 1) Several packages each use their own fake MPI, everything is
>>>>> fine
>>>>> unless two
>>>>> different mpi.h's get included but that should not happen.
>>>> One of the ways it can conflict is:
>>>> 'include' package1/mpif.h'
>>>> 'include mpiuni/mpif.h
>>>> and there will be duplicate variable conflicts for constants
>>>> like MPI_COMM_WORLD, and others.
>>>> I'll admit the old way of using mpiuni with other packages does not
>>>> work with all packages. [only with a select few codes that facets
>>>> folks tested with].
>>>>> 2) Several packages each use PETSc's fake MPI. To support this
>>>>> we only
>>>>> need to
>>>>> have them add -I$PETSC_DIR/include/mpiuni in their compiles
>>>> In this case - the user should be consious that he needs mpiuni
>>>> from
>>>> user code - and enable another petsc build option? [or create
>>>> unportable makefile]. One more additional cost to the current
>>>> imperfect change.
>>>> So I still prefer the previous scheme.
>>>> Satish
>>>>>> So I still prefer previous secheme. If that not acceptable -
>>>>>> then I
>>>>>> guess we have to go with Matt's scheme [ slplit up mpiuni into a
>>>>>> different package, add build/make support to it - and deal with
>>>>>> all
>>>>>> the petsc-maint that creates..]. But the current change really
>>>>>> breaks
>>>>>> things - so we should not do this.
>>>>>> Satish
>>>>>> On Thu, 25 Feb 2010, Barry Smith wrote:
>>>>>>> After listening to our discussion of the half-plant/half animal
>>>>>>> handling
>>>>>>> of
>>>>>>> MPIUni I have adopted the plant :-) model.
>>>>>>> Background: All the packages in PETSc/packages and
>>>>>>> BuildSystem/config/packages
>>>>>>> have the following paradigm except MPI and BlasLapack.
>>>>>>> 1) PETSc can be built --with-package or --with-package=0
>>>>>>> 2) If --with-package=0 then there is no PETSC_HAVE_package
>>>>>>> defined,
>>>>>>> no
>>>>>>> extra
>>>>>>> libraries to link against and no extra include paths to look in
>>>>>>> BlasLapack breaks this paradigm in only one way! You cannot use
>>>>>>> --with-blaspack=0
>>>>>>> MPI breaks the paradigm more completely. You can use --with-
>>>>>>> mpi=0
>>>>>>> BUT if
>>>>>>> you
>>>>>>> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!!
>>>>>>> There is
>>>>>>> an
>>>>>>> extra
>>>>>>> library to link against and an extra include path to look in.
>>>>>>> The two possible solutions to resolve this perverse beast are
>>>>>>> 1) make mpiuni be a --download-mpiuni replacement for MPI, as
>>>>>>> we do
>>>>>>> --download-c-blaslapack (this would replace the current --with-
>>>>>>> mpi=0
>>>>>>> support).
>>>>>>> 2) better supporting --with-mpi=0 without breaking the paradigm
>>>>>>> I agree with Matt that 1 is the more elegant solution, since
>>>>>>> it fits
>>>>>>> the
>>>>>>> paradigm perfectly. But having --with-mpi=0 is easier and more
>>>>>>> understandable
>>>>>>> to the user then explaining about downloading a dummy MPI.
>>>>>>> Thus I have implemented and pushed 2). When you use --with-mpi=0
>>>>>>> 1) the macro PETSC_HAVE_MPI is not set
>>>>>>> 2) the list of include directories is not added to
>>>>>>> 3) the list of linked against libraries is not added to.
>>>>>>> I have implemented 2) and 3) by having in petsc.h (fortran also)
>>>>>>> #if defined(PETSC_HAVE_MPI)
>>>>>>> #include "mpi.h"
>>>>>>> #else
>>>>>>> #include "mpiuni/mpi.h"
>>>>>>> #endif
>>>>>>> and putting the dummy MPI stubs always into the PETSc
>>>>>>> libraries for
>>>>>>> both
>>>>>>> single library and multiple library PETSc installs.
>>>>>>> Note: this means one cannot have an include "mpi.h" in the uni
>>>>>>> case
>>>>>>> which
>>>>>>> bothered me initially but then Lisandro convinced me it was
>>>>>>> not a
>>>>>>> bad
>>>>>>> thing.
>>>>>>> The actual code changes to implement this were, of course,
>>>>>>> tiny. It
>>>>>>> is not
>>>>>>> perfect (only --download-mpiuni would be perfect :-), but it is
>>>>>>> better
>>>>>>> than
>>>>>>> before.
>>>>>>> Sorry Matt,
>>>>>>> Barry
