[petsc-dev] dealing with MPIUNi
Fri Feb 26 13:00:36 CST 2010
1)  So FACETS Fortran code includes mpif.h directly AND includes PETSc
includes in the same file? Can those extra includes just be removed
from FACETS.
2)  Some FACES codes, or other packages that FACETS use THAT DO NOT
use PETSc can/do use PETSc's mpiuni mpif.h?
   Are these ONLY conflict with the new MPI unimodel and FACETS or are
there other conflicts?
   Is there any issue with not having a separate libmpiuni.a ?
   Barry
On Feb 26, 2010, at 12:46 PM, Satish Balay wrote:
> On Fri, 26 Feb 2010, Barry Smith wrote:
>> On Feb 26, 2010, at 11:22 AM, Satish Balay wrote:
>>> I think eliminating mpi.h, mpi.mod etc is not a good change. Its
>>> likely to break users codes.  I suspect it breaks FACETS. [and
>>> perhaps
>>> Flotran]
>>  Suspect isn't good enough. HOW does it break FACETS? It won't
>> break pflotran
>> unless they have #include "mpi.h" directly in their code
> Just for this reason [prohibiting using 'mpi.h'/mpif.h from user code
> - if one wants --with-mpi=0] the current change is bad
> I've explained the facets/uedge model used below.  I'll check uedge
> usage. I'll have to ask facets folks to check other usages..
>>> With this change we will continue to have MPI symbols [esp from
>>> fortran] in libpetsc.a. So this is not really clean absorbtion of
>>> mpiuni into petsc. And I don't think we can avoid having these MPI
>>> symbols in -lpetsc.
>>  Yes the fake "symbols" are in libpetsc.a but what is wrong with
>> that? What
>> is the disadvantage over having them in libmpiuni.a?
>>> The fact that MPI API symbols exist in libpetsc.a makes PETSc not
>>> really pure plant. Its still a plant/animal - so the goal of this
>>> code
>>> reorganization is still not met.
>>  As I said in my previous email; only Matt's plan is perfect.
> My argument is - the change mode is still imperfect - but at the cost
> of breaking some user codes. [so its not worth the cost].
>>> [I might not have raised this issue earlier wrt merging mpiuni
>>> completely into petsc - thats my omission sorry about that.]
>>> I suspec the following usage in FACETS/UEDGE will break with this
>>> change:
>>> If you have package-A doing the same type of thing for its
>>> sequential
>>> implementation - it will have its own mpi_comm_size() etc
>>> internally.
>>> With this - mixing package-A with petsc-sequential will cause
>>> duplicate symbol conflict.
>>  The fix is to not have any symbols in MPIUNI that are called
>> MPI_xxx This is
>> handled in mpiunis mpi.h with
>> #if defined(MPIUNI_AVOID_MPI_NAMESPACE)
>> we should just ALWAYS avoid the MPI Namespace
>>> The way I'm currently resolving this issue is: Only one package
>>> should
>>> provide [internal] MPI - the other package is compiled with
>>> --with-mpi=enabled.
>>> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is now
>>> compiled with MPI-ENABLED - but links with PETSc - that provides
>>> MPIUNI - as MPI.
>>> Also due to this - we added more stuff to MPUNI to cover all MPI
>>> symbol usage from FACETS.
>>> So - the previous MPIUNI implementation scheme eventhough slightly
>>> inconsistant, provided good user interface - with minimal
>>> maintainance
>>> overhead.. Matt's schem makes everything consistant - but with extra
>>> maintainance overhead.
>>  We can certainly go back to the way it was if we need to. But you
>> have not
>> demonstrated that need, you've only speculated.
>> Here is how it should work ok.
>> 1) Several packages each use their own fake MPI, everything is fine
>> unless two
>> different mpi.h's get included but that should not happen.
> One of the ways it can conflict is:
> 'include' package1/mpif.h'
> 'include mpiuni/mpif.h
> and there will be duplicate variable conflicts for constants
> like MPI_COMM_WORLD, and others.
> I'll admit the old way of using mpiuni with other packages does not
> work with all packages. [only with a select few codes that facets
> folks tested with].
>> 2) Several packages each use PETSc's fake MPI. To support this we
>> only need to
>> have them add -I$PETSC_DIR/include/mpiuni in their compiles
> In this case - the user should be consious that he needs mpiuni from
> user code - and enable another petsc build option? [or create
> unportable makefile]. One more additional cost to the current
> imperfect change.
> So I still prefer the previous scheme.
> Satish
>>> So I still prefer previous secheme. If that not acceptable - then I
>>> guess we have to go with Matt's scheme [ slplit up mpiuni into a
>>> different package, add build/make support to it - and deal with all
>>> the petsc-maint that creates..]. But the current change really
>>> breaks
>>> things - so we should not do this.
>>> Satish
>>> On Thu, 25 Feb 2010, Barry Smith wrote:
>>>> After listening to our discussion of the half-plant/half animal
>>>> handling
>>>> of
>>>> MPIUni I have adopted the plant :-) model.
>>>> Background: All the packages in PETSc/packages and
>>>> BuildSystem/config/packages
>>>> have the following paradigm except MPI and BlasLapack.
>>>> 1) PETSc can be built --with-package or --with-package=0
>>>> 2) If --with-package=0 then there is no PETSC_HAVE_package
>>>> defined, no
>>>> extra
>>>> libraries to link against and no extra include paths to look in
>>>> BlasLapack breaks this paradigm in only one way! You cannot use
>>>> --with-blaspack=0
>>>> MPI breaks the paradigm more completely. You can use --with-mpi=0
>>>> BUT if
>>>> you
>>>> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!! There
>>>> is an
>>>> extra
>>>> library to link against and an extra include path to look in.
>>>> The two possible solutions to resolve this perverse beast are
>>>> 1) make mpiuni be a --download-mpiuni replacement for MPI, as we do
>>>> --download-c-blaslapack (this would replace the current --with-
>>>> mpi=0
>>>> support).
>>>> 2) better supporting --with-mpi=0 without breaking the paradigm
>>>> I agree with Matt that 1 is the more elegant solution, since it
>>>> fits the
>>>> paradigm perfectly. But having --with-mpi=0 is easier and more
>>>> understandable
>>>> to the user then explaining about downloading a dummy MPI.
>>>> Thus I have implemented and pushed 2). When you use --with-mpi=0
>>>> 1) the macro PETSC_HAVE_MPI is not set
>>>> 2) the list of include directories is not added to
>>>> 3) the list of linked against libraries is not added to.
>>>> I have implemented 2) and 3) by having in petsc.h (fortran also)
>>>> #if defined(PETSC_HAVE_MPI)
>>>> #include "mpi.h"
>>>> #else
>>>> #include "mpiuni/mpi.h"
>>>> #endif
>>>> and putting the dummy MPI stubs always into the PETSc libraries
>>>> for both
>>>> single library and multiple library PETSc installs.
>>>> Note: this means one cannot have an include "mpi.h" in the uni
>>>> case which
>>>> bothered me initially but then Lisandro convinced me it was not a
>>>> bad
>>>> thing.
>>>> The actual code changes to implement this were, of course, tiny.
>>>> It is not
>>>> perfect (only --download-mpiuni would be perfect :-), but it is
>>>> better
>>>> than
>>>> before.
>>>> Sorry Matt,
>>>> Barry
