[petsc-dev] dealing with MPIUNi
Fri Feb 26 11:22:24 CST 2010
I think eliminating mpi.h, mpi.mod etc is not a good change. Its
likely to break users codes.  I suspect it breaks FACETS. [and perhaps
Flotran]
With this change we will continue to have MPI symbols [esp from
fortran] in libpetsc.a. So this is not really clean absorbtion of
mpiuni into petsc. And I don't think we can avoid having these MPI
symbols in -lpetsc.
The fact that MPI API symbols exist in libpetsc.a makes PETSc not
really pure plant. Its still a plant/animal - so the goal of this code
reorganization is still not met.
[I might not have raised this issue earlier wrt merging mpiuni
completely into petsc - thats my omission sorry about that.]
I suspec the following usage in FACETS/UEDGE will break with this
change:
If you have package-A doing the same type of thing for its sequential
implementation - it will have its own mpi_comm_size() etc internally.
With this - mixing package-A with petsc-sequential will cause
duplicate symbol conflict.
The way I'm currently resolving this issue is: Only one package should
provide [internal] MPI - the other package is compiled with
--with-mpi=enabled.
I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is now
compiled with MPI-ENABLED - but links with PETSc - that provides
MPIUNI - as MPI.
Also due to this - we added more stuff to MPUNI to cover all MPI
symbol usage from FACETS.
So - the previous MPIUNI implementation scheme eventhough slightly
inconsistant, provided good user interface - with minimal maintainance
overhead.. Matt's schem makes everything consistant - but with extra
maintainance overhead.
So I still prefer previous secheme. If that not acceptable - then I
guess we have to go with Matt's scheme [ slplit up mpiuni into a
different package, add build/make support to it - and deal with all
the petsc-maint that creates..]. But the current change really breaks
things - so we should not do this.
Satish
On Thu, 25 Feb 2010, Barry Smith wrote:
> After listening to our discussion of the half-plant/half animal handling of
> MPIUni I have adopted the plant :-) model.
> Background: All the packages in PETSc/packages and BuildSystem/config/packages
> have the following paradigm except MPI and BlasLapack.
> 1) PETSc can be built --with-package or --with-package=0
> 2) If --with-package=0 then there is no PETSC_HAVE_package defined, no extra
> libraries to link against and no extra include paths to look in
> BlasLapack breaks this paradigm in only one way! You cannot use
> --with-blaspack=0
> MPI breaks the paradigm more completely. You can use --with-mpi=0 BUT if you
> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!! There is an extra
> library to link against and an extra include path to look in.
> The two possible solutions to resolve this perverse beast are
> 1) make mpiuni be a --download-mpiuni replacement for MPI, as we do
> --download-c-blaslapack (this would replace the current --with-mpi=0 support).
> 2) better supporting --with-mpi=0 without breaking the paradigm
>  I agree with Matt that 1 is the more elegant solution, since it fits the
> paradigm perfectly. But having --with-mpi=0 is easier and more understandable
> to the user then explaining about downloading a dummy MPI.
>  Thus I have implemented and pushed 2). When you use --with-mpi=0
> 1) the macro PETSC_HAVE_MPI is not set
> 2) the list of include directories is not added to
> 3) the list of linked against libraries is not added to.
> I have implemented 2) and 3) by having in petsc.h (fortran also)
> #if defined(PETSC_HAVE_MPI)
> #include "mpi.h"
> #else
> #include "mpiuni/mpi.h"
> #endif
> and putting the dummy MPI stubs always into the PETSc libraries for both
> single library and multiple library PETSc installs.
> Note: this means one cannot have an include "mpi.h" in the uni case which
> bothered me initially but then Lisandro convinced me it was not a bad thing.
> The actual code changes to implement this were, of course, tiny. It is not
> perfect (only --download-mpiuni would be perfect :-), but it is better than
> before.
> Sorry Matt,
>   Barry
