[petsc-dev] now that we have -lpetsc should we also have #include "petsc.h"?
Thu Feb 25 16:27:51 CST 2010
   We can install PETSc with the option --with-single-library so that
one links against -lpetsc instead of -lpetscts -lpetscsnes ... -
lpetscsys
   This suggests that with include files we should have a parallel
construct where one can do #include "petsc.h" to access all of PETSc's
functionality (while, of course, continuing to be able to include just
some some includes if you like).
   I propose the following, change petsc.h to petsccore.h and
introduce a new petsc.h that is basically petscts.h
   What does everyone think?
   Notes:
* Current C compiles won't break if users do not update there code
(just everything will be included if they happen to have a #include
"petsc.h")
* Most users likely have include "petscksp.h" or "petscsnes.h" already
in their code won't even have to change things to match the new
"paradigm", the need only remove the "petsc.h" that they have now
before other includes (which they never needed).
* Fortran is a bit trickier so things might break for some users
* Implementing this change means I go though the source code replacing
"petsc.h" everywhere with "petsccore.h" no big deal.
   I really like this idea, in fact I like it so much I just want to
do it this moment and push and be done with it, BUT I'll listen to
your screams first in case I am missing something.
    Barry
