[petsc-dev] Writing rich state
Dmitry Karpeev karpeev at mcs.anl.gov
Wed Feb 24 09:25:39 CST 2010
On Wed, Feb 24, 2010 at 9:09 AM, Jed Brown <jed at 59a2.org> wrote:
> On Wed, 24 Feb 2010 08:31:32 -0600, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> Yes, I think SQL or some such approach would be a good solution.
>> I don't even think the actual file format matters too much: we can just
>> create collections of files that share keys.  The database is needed only
>> to manage file names.  It could also store other data, of course, but
>> that's just gravy.
> I think the database needs to hold a nontrivial amount of semantic
> information.  For example, suppose we have a DMComposite covering
> multiple domains, with some domains having more than one DM on the same
> mesh (as in mixed FEM).  These DMs will share coordinate DMs and the
> associated position vectors (which may be time-dependent).  Other
> metadata, such as precision, endianness, units, scaling factors, time,
> and projections, would (in my opinion) also go in the database so that
> everything can be wired up without opening these files, and they can be
> slurped in with a single collective read.
Here's the main problem that I see: are file attributes stored in the database
fixed?  That could be somewhat inflexible (what if some attributes don't apply
to a given file?  what if I want to add another attribute?).  The alternative
is to manage this with (key,value) string pairs (e.g., ("precision",
"double") etc).
Is there a way to encode that in a relational database and maintain
good performance?
>> Yes, labels are cumbersome, since they have to be create manually, etc.
>> However, when we decide where on the filesystem to place a file, we are
>> essentially selecting its labels: the directories on the path.  At least those
>> are *some* of the labels we'd like to attach to the file and the filesystem only
>> allows "labels" encoded as directories.  I agree that it would be nice to allow
>> more general queries, but based on what (permissions, timestamp? those
>> sound like natural candidates)?
> I wasn't thinking of filesystem metadata at all, it's the user-visible
> attributes and relationship among objects in the simulation that are
> significant.  We have to drop the files somewhere and give them a name,
> but I'd be happy if they were just named by SHA1.  The name has no
> significance since you can't do anything with it without the semantic
> information in the database.
Storing files on the filesystem using a hash sounds like a good idea to me.
Dmitry.
> Jed
