[petsc-dev] amount of history displayed in hg/murky
Sean Farley sean at mcs.anl.gov
Tue Feb 23 13:07:43 CST 2010
>  Is there a way to limit how much history of the graph is displayed in
> murky/hg? For example, I'd like default to just show the last couple of
> hundred change sets.
Currently, there is not. This should be an easy fix, though. I will push a
change this evening. A bigger change would be to generate the graph a
completely different way. I'm still investigating that, though, but some
other ideas for that would be helpful :-)
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100223/bd40403e/attachment.html>
