[petsc-dev] Murky
Sean Farley sean at mcs.anl.gov
Sun Feb 21 17:12:48 CST 2010
 Nope, I removed that link and tried with adding it as you suggested. Same
> damn thing.
Have you tried with removing the link completely and see if it works?
  Have you tried messing around with having not having a PYTHONPATH?
I don't have a PYTHONPATH set. For this VM I'm using the system python. In
fact, the *only* thing I've installed is the binary mercurial 1.4.3 for 10.5
http://mercurial.berkwood.com/
and Murky 0.7.1.
Something is very strange here.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100221/d537e7d9/attachment.html>
