[petsc-dev] Murky
Sean Farley sean at mcs.anl.gov
Sun Feb 21 16:52:41 CST 2010
>  I think it is the leopard vs snow leopard business.
Barry, I just installed Leopard in a virtual machine and I got Murky to work
just fine with default installs.
I recreated the sym link and permissions you have for /usr/bin/hg but even
that still worked! To finally get the same error you received, I had to
create a Mac alias for /usr/bin/hg. Is that how you created it?
Anyway, removing that link, or replacing it with:
sudo ln -s /usr/local/bin/hg /usr/bin/hg
should make Murky work.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100221/197ab0e1/attachment.html>
