[petsc-dev] [petsc-maint #40976] convert a matrix from CSR format to BCSR format
Tue Feb 16 21:08:05 CST 2010
   --with-blas-lapack=0 doesn't work.
   --with-mpi=0 is actually a lie because there is an MPI package that
is used; yes it is limited and doesn't work in parallel, it is like
the old --download-c-blas-lapack
   Barry
On Feb 16, 2010, at 9:04 PM, Satish Balay wrote:
> Added note:
> we do have --with-blacs=0 --with-hypre=0 etc - so --with-mpi=0 is not
> one of a kind option that need eliminating.
> We default to --with-mpi=1 --with-blas-lapack=1 [as there are the
> basic dependencies for PETSc ], and --with-PACKAGENAME=0 for every
> other PACKAGENAME.
> The user has to explicitly enable other packages. [either by
> --download-PACAKGE or --with-PACKAGE=1 option - if its installed in
> standard search PATHs]
> --with-x is the funky one thats automatically enabled - if configure
> is able to find it.
> satish
> On Tue, 16 Feb 2010, Satish Balay wrote:
>> For one - the interface most users are looking for is
>> --with-sequential - or --without-mpi - which '-with-mpi=0'
>> represents.. They don't know are care about mpiuni [so download-
>> mpiuni
>> is not really better]
>> Also mpiuni is not distributed or built separately from petsc
>> sources/makefiles - and is akin to --with-sieve=1
>> Blas/lapack is not optional - hence no --with-blas-lapack=0 support.
>> Satish
>> On Tue, 16 Feb 2010, Barry Smith wrote:
>>>   --download-c-blas-lapack puts "bad" Blas/LAPACK into its own
>>> library. There is no --with-blaslapack=0
>>>   Shouldn't  we eliminate -with-mpi=0 and instead have --download-
>>> mpiuni
>>>    Barry
>>>    Removes one more special case, and special cases are BAD! So
>>> obviously it is a good idea, let's see if anyone has a legitimate
>>> reason for rejecting it instead of knee-jerk conservatism.
>>> On Feb 16, 2010, at 8:31 PM, Satish Balay wrote:
>>>> This is a conflict with --with-mpi=0 and the curent default
>>>> --with-single-library=1
>>>> Ideally we should create libmpiuni.a [and a .so] even with
>>>> --with-single-library=1 - but I'm not sure how to do that
>>>> cleanly. So
>>>> my current fix is to remove libmpiuni.a for
>>>> --with-single-library=1. [i.e libpetsc.a will have the mpiuni
>>>> stuff as
>>>> well]
>>>> Testing this change - and will push once I verify.
>>>> Satish
>>>> On Tue, 16 Feb 2010, Matthew Knepley wrote:
>>>>> On Tue, Feb 16, 2010 at 8:16 PM, Dahai Guo <dhguo at ncsa.uiuc.edu>
>>>>> wrote:
>>>>>> Thanks, Barry.
>>>>>> I tried to configure and built petsc-dev on AIX with the
>>>>>> following
>>>>>> options,
>>>>>> but failed when "make test" as follow "ld: 0706-006 Cannot find
>>>>>> or
>>>>>> open
>>>>>> library file: -l mpiuni". I  used the same options for petsc-3.0,
>>>>>> everything
>>>>>> is fine. Would you tell me how to fix it?
>>>>> Always send configure.log
>>>>> Matt
>>>>>> Dahai
>>>>>> export OBJECT_MODE=64  # for 64/32-bit ar
>>>>>> export PETSC_DIR=$PWD
>>>>>> config/configure.py  --with-mpi=0 --with-64-bit-pointers=1  --
>>>>>> with-
>>>>>> cc=xlc_r
>>>>>> --with-cxx=xlC_r --with-fc=xlf_r COPTFLAGS='-q64 -O3 -qstrict -
>>>>>> qmaxmem=-1
>>>>>> -qarch=pwr6 -qtune=pwr6' FOPTFLAGS='-q64 -O3 -qstrict -qmaxmem=-1
>>>>>> -qarch=pwr6 -qtune=pwr6' CXXOPTFLAGS='-q64 -O3 -qstrict -
>>>>>> qmaxmem=-1
>>>>>> bash-3.1$ make test
>>>>>> Running test examples to verify correct installation
>>>>>> --------------Error detected during compile or
>>>>>> link!-----------------------
>>>>>> See
>>>>>> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
>>>>>> xlc_r -o ex19.o -c -q64 -O3 -qstrict -qmaxmem=-1 -qarch=pwr6 -
>>>>>> qtune=pwr6
>>>>>> -I/blhome/dhguo/petsc-dev/aix5.3.0.0-c-debug/include
>>>>>> -I/blhome/dhguo/petsc-dev/include -I/blhome/dhguo/petsc-dev/
>>>>>> include/mpiuni
>>>>>> -D__SDIR__="src/snes/examples/tutorials/" ex19.c
>>>>>>       xlc_r -q64 -O3 -qstrict -qmaxmem=-1 -qarch=pwr6 -
>>>>>> qtune=pwr6  -o
>>>>>> ex19  ex19.o -L/blhome/dhguo/petsc-dev/aix5.3.0.0-c-debug/lib
>>>>>> -L/blhome/dhguo/petsc-dev/aix5.3.0.0-c-debug/lib -lpetsc  -lX11 -
>>>>>> lessl
>>>>>> -L/blhome/dhguo/petsc-dev/aix5.3.0.0-c-debug/lib -lmpiuni -lm -
>>>>>> ldl
>>>>>> -L/usr/vac/lib -lxlopt -lxl -lpthreads -lxlf90 -L/usr/lpp/xlf/
>>>>>> lib -
>>>>>> lxlf
>>>>>> -lxlomp_ser -lm -ldl -lxlopt -lxl -lpthreads -ldl
>>>>>> ld: 0706-006 Cannot find or open library file: -l mpiuni
>>>>>>       ld:open(): No such file or directory
>>>>>> make: The error code from the last command is 255.
>>>>>> make: Ignored error code 255 from last command.
>>>>>>       /usr/linux/bin/rm -f ex19.o
>>>>>> See
>>>>>>       xlf_r -c  -q64 -O3 -qstrict -qmaxmem=-1 -qarch=pwr6 -
>>>>>> qtune=pwr6
>>>>>> include/mpiuni
>>>>>> -I/blhome/dhguo/petsc-dev/include/mpiuni    -o ex5f.o ex5f.F
>>>>>> ** main   === End of Compilation 1 ===
>>>>>> ** forminitialguess   === End of Compilation 2 ===
>>>>>> ** initialguesslocal   === End of Compilation 3 ===
>>>>>> ** formfunctionlocal   === End of Compilation 4 ===
>>>>>> ** formjacobianlocal   === End of Compilation 5 ===
>>>>>> 1501-510  Compilation successful for file ex5f.F.
>>>>>>       xlf_r -q64 -O3 -qstrict -qmaxmem=-1 -qarch=pwr6 -
>>>>>> qtune=pwr6   -o
>>>>>> ex5f ex5f.o -L/blhome/dhguo/petsc-dev/aix5.3.0.0-c-debug/lib
>>>>>> lessl
>>>>>> ldl
>>>>>> lib -
>>>>>> lxlf
>>>>>>       /usr/linux/bin/rm -f ex5f.o
>>>>>> Completed test examples
>>>>>> ----- Original Message -----
>>>>>> From: "Barry Smith" <bsmith at mcs.anl.gov>
>>>>>> To: petsc-maint at mcs.anl.gov, "Dahai Guo" <dhguo at ncsa.uiuc.edu>
>>>>>> Sent: Tuesday, February 16, 2010 1:40:53 PM GMT -06:00 Central
>>>>>> America
>>>>>> Subject: Re: [petsc-maint #40976] convert a matrix from CSR
>>>>>> format
>>>>>> to BCSR
>>>>>> format
>>>>>>  Sorry, I forgot to check the code last weekend.
>>>>>>  I cannot reproduce your problem.
>>>>>>  Looks like you are using petsc 3.0.0. That is completely insane!
>>>>>> This problem has been fixed for a year. You should be using
>>>>>> petsc-
>>>>>> dev
>>>>>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
>>>>>> it will make your live much easier.
>>>>>>   Barry
>>>>>> On Feb 15, 2010, at 10:38 AM, Dahai Guo wrote:
>>>>>>> Barry:
>>>>>>> In the function “MatGetFactor” in src/mat/interface/matrix.c, it
>>>>>>> only checks if the matsolver is available for subclass, but NOT
>>>>>>> further check for the AIJ/BAIJ.    I think it is one of the
>>>>>>> reasons
>>>>>>> that a subclass(e.g. crl ) inherited from AIJ/BAIJ can not
>>>>>>> inherit
>>>>>>> "MatGetFactor" from AIJ/BAIJ.
>>>>>>> Is there some special reason for designing it in this way? Or
>>>>>>> it is
>>>>>>> just a bug? How to improve it? Please advise.
>>>>>>> Thanks,
>>>>>>> Dahai
>>>>>>> Sent: Thursday, February 11, 2010 9:45:24 PM GMT -06:00 US/
>>>>>>> Canada
>>>>>>> Central
>>>>>>> format
>>>>>>> to BCSR format
>>>>>>>  Dahai,
>>>>>>>    You have to switch to a decent email client. Stuff you send
>>>>>>> is
>>>>>>> never in attachments, it is always crammed into the message as
>>>>>>> one
>>>>>>> long piece of text.
>>>>>>>    I'll try to reproduce the problem tomorrow,
>>>>>>>   Barry
>>>>>>> On Feb 11, 2010, at 8:01 PM, Dahai Guo wrote:
>>>>>>>> tried CSR format, it showed the similar problem as follow.??? I
>>>>>>>> attached the test code and datafile.
>>>>>>> Barry:
>>>>>>> reasons
>>>>>>> inherit
>>>>>>> it is
>>>>>>> Thanks,
>>>>>>> Dahai
>>>>>>> Canada
>>>>>>> Central
>>>>>>> format
>>>>>>> to BCSR format
>>>>>>>  Dahai,
>>>>>>> is
>>>>>>> one
>>>>>>> long piece of text.
>>>>>>>   Barry
>>>>>> Thanks, Barry.
>>>>>> following
>>>>>> options,
>>>>>> or
>>>>>> open
>>>>>> everything
>>>>>> Dahai
>>>>>> with-
>>>>>> cc=xlc_r
>>>>>> qmaxmem=-1
>>>>>> qmaxmem=-1
>>>>>> bash-3.1$ make test
>>>>>> See
>>>>>> qtune=pwr6
>>>>>> include/mpiuni
>>>>>> qtune=pwr6  -o
>>>>>> lessl
>>>>>> ldl
>>>>>> lib -
>>>>>> lxlf
>>>>>> See
>>>>>> qtune=pwr6
>>>>>> include/mpiuni
>>>>>> qtune=pwr6   -o
>>>>>> lessl
>>>>>> ldl
>>>>>> lib -
>>>>>> lxlf
>>>>>> America
>>>>>> format
>>>>>> to BCSR
>>>>>> format
>>>>>> petsc-
>>>>>> dev
>>>>>>   Barry
>>>>>>> Barry:
>>>>>>> reasons
>>>>>>> inherit
>>>>>>> it is
>>>>>>> Thanks,
>>>>>>> Dahai
>>>>>>> Canada
>>>>>>> Central
>>>>>>> format
>>>>>>> to BCSR format
>>>>>>>  Dahai,
>>>>>>> is
>>>>>>> one
>>>>>>> long piece of text.
>>>>>>>   Barry
>>>>>>> Barry:
>>>>>>> reasons
>>>>>>> inherit
>>>>>>> it is
>>>>>>> Thanks,
>>>>>>> Dahai
>>>>>>> Canada
>>>>>>> Central
>>>>>>> format
>>>>>>> to BCSR format
>>>>>>>  Dahai,
>>>>>>> is
>>>>>>> one
>>>>>>> long piece of text.
>>>>>>>   Barry
