[petsc-dev] [GPU] Performance on Fermi
Keita Teranishi keita at cray.com
Fri Aug 27 14:19:56 CDT 2010
Barry,
Yes. It improves the performance dramatically, but the execution time for KSPSolve stays the same.
MatMult 5.2 Gflops
 Keita Teranishi
 Scientific Library Group
 Cray, Inc.
 keita at cray.com
-----Original Message-----
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Friday, August 27, 2010 2:15 PM
To: For users of the development version of PETSc
Subject: [petsc-dev] [GPU] Performance on Fermi
   PETSc-dev folks,
      Please prepend all messages to petsc-dev that involve GPUs with [GPU] so they can be easily filtered.
    Keita,
      To run src/ksp/ksp/examples/tutorials/ex2.c with CUDA you need the flag -vec_type cuda
      Note also that this example is fine for simple ONE processor tests but should not be used for parallel testing because it does not do a proper parallel partitioning for performance
    Barry
On Aug 27, 2010, at 2:04 PM, Keita Teranishi wrote:
> Hi,
> I ran ex2.c with a matrix from 512x512 grid.
> I set CG and Jacobi for the solver and preconditioner.
> GCC-4.4.4 and CUDA-3.1 are used to compile the code.
> BLAS and LAPAKCK are not optimized.
> MatMult
> Fermi: 		1142 MFlops
> 1 core Istanbul:	420 MFlops
> KSPSolve:
> Fermi:			1.5 Sec
> 1 core Istanbul:	1.7 Sec
>  Keita Teranishi
>  Cray, Inc.
>  keita at cray.com
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Friday, August 27, 2010 1:49 PM
> Subject: Re: [petsc-dev] Problem with petsc-dev
> On Fri, 27 Aug 2010, Satish Balay wrote:
>> There was a problem with tarball creation for the past few days. Will
>> try to respin manually today - and update you.
> the petsc-dev tarball is now updated on the website..
> Satish
Desc: out_fermi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100827/b6b29cf3/attachment.obj>
