[petsc-dev] no module named cmakegen
Leo van Kampenhout lvankampenhout at gmail.com
Mon Aug 23 06:45:23 CDT 2010
Hi Aron,
I try now to configure the Mercurial version of Petsc-dev. However, the
script gets stuck in some kind of "infinite" loop, producing this text over
and over again. What should I do now?
-- The C compiler identification is GNU
-- Check for working C compiler: /opt/local/bin/mpicc
-- Check for working C compiler: /opt/local/bin/mpicc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- The Fortran compiler identification is GNU
-- Check for working Fortran compiler: mpif90
-- Check for working Fortran compiler: mpif90 -- works
-- Checking whether mpif90 supports Fortran 90
-- Checking whether mpif90 supports Fortran 90 -- yes
-- Configuring done
You have changed variables that require your cache to be deleted.
Configure will be re-run and you may have to reset some variables.
The following variables have changed:
CMAKE_Fortran_COMPILER= mpif90
Leo
2010/8/23 Aron Ahmadia <aron at ahmadia.net>
> Hi Leo,
> Yes.
> A
> On Mon, Aug 23, 2010 at 2:19 PM, Leo van Kampenhout <
> lvankampenhout at gmail.com> wrote:
>> Hi Aron,
>> I'm using the nightly tarball. Do you propose using mercurial? I can try
>> that.
>> Leo
>> Hi Leo,
>>> Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
>>> A
>>> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
>>>> Hi all,
>>>> I'm trying to install PETSc-dev on my desktop machine. This is what goes
>>>> wrong. I suspect the line
>>>>  import cmakegen [line 409]
>>>> in the configure.py is the cause. The version of Cmake installed on my
>>>> system is 2.6
>>>> Best regards,
>>>> Leo van Kampenhout
>>>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
>>>>              Configuring PETSc to compile on your
>>>> system
>>>> TESTING: configureFortranFlush from
>>>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
>>>>                      UNABLE to FIND MODULE for ./configure
>>>> No module named cmakegen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/74630eab/attachment.html>
