[petsc-dev] petsc-dev hg server still hosed?
Dmitry Karpeev karpeev at mcs.anl.gov
Wed Apr 28 10:06:45 CDT 2010
Yep.  Just pushed.  Thanks, Satish.
Dmitry.
On Wed, Apr 28, 2010 at 9:52 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> I think It should be the following - but will let Dmitry check/fix it..
> Satish
>  ierr = MatRegisterDynamic(MATDD,            path,"MatCreate_DD",   MatCreate_DD);CHKERRQ(ierr);
> #if defined PETSC_HAVE_MATIM
>  ierr = MatRegisterDynamic(MATIM,             path,"MatCreate_IM",   MatCreate_IM);CHKERRQ(ierr);
> #endif
> On Wed, 28 Apr 2010, Hong Zhang wrote:
>> Dmitry,
>> Petsc repo server is down due to bad hard disc.
>> We are replacing it with a new disc - hopefully to get it back as soon
>> as possible.
>> I get build error about Matfwk, and pushed a fix:
>>   ierr = MatRegisterDynamic(MATFWK,            path,"MatCreate_DD",
>> #endif
>> If this is not correct, please revise.
>> Hong
>> On Wed, Apr 28, 2010 at 9:34 AM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> > I just tried pulling, but timed out.
>> > Dmitry.
