[petsc-dev] PETSc packages are way out of date
Sean Farley sean at mcs.anl.gov
Sun Apr 25 12:00:23 CDT 2010
>    Cool, can make these accessable from the PETSc download page?
Sure!
>    How do you handle different versions of MPI?
What do you mean? If you mean, say, different compilers, then this is
handled with 'variants'
http://guide.macports.org/chunked/reference.variants.html
e.g.
$ port installed mpich2
mpich2 @1.0.8_0+darwin+gfortran
mpich2 @1.0.8_0+darwin+gcc44
mpich2 @1.0.8_0+darwin+gcc45
mpich2 @1.2.1p1_0+darwin+gcc44+gforker
mpich2 @1.2.1p1_0+darwin+gcc45+gforker
mpich2 @1.2.1p1_0+darwin+gforker+gfortran (active)
mpich2 @1.3a1_0+darwin+gcc44+hydra
mpich2 @1.3a1_0+darwin+gcc45+hydra
mpich2 @1.3a1_0+darwin+gfortran+hydra
To switch between them:
$ port activate mpich2 @1.3a1_0+darwin+gcc45+hydra
Is this what you mean?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100425/082b3615/attachment.html>
