[petsc-dev] Need help compiling on Windows (Cygwin)
Olumide 50295 at web.de
Fri Apr 23 15:11:21 CDT 2010
Hi -
I'm having difficulty compiling on Windows (Cygwin). I've installed
MPICH2, but I keep getting the following error (extract from
configure.log). I've also tried specifying the directory in which MPI is
installed, but that didn't work either.
BTW, I do not have ifort on my machine (can't afford it :( ).
- Olumide
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Error running configure on MPICH.
    On Microsoft Windows systems, please obtain and install the binary
distribution from
      http://www.mcs.anl.gov/mpi/mpich/mpich-nt
    then rerun configure.
    If you choose to install MPICH to a location other than the default,
use
      --with-mpi-dir=<directory>
    to specify the location of the installation when you rerun configure.
   File "./configure", line 250, in petsc_configure
     framework.configure(out = sys.stdout)
   File
"/cygdrive/c/Downloads/src/petsc-dev/config/BuildSystem/config/framework.py",
line 930, in configure
     child.configure()
   File
"/cygdrive/c/Downloads/src/petsc-dev/config/BuildSystem/config/package.py",
line 457, in configure
     self.executeTest(self.configureLibrary)
   File
"/cygdrive/c/Downloads/src/petsc-dev/config/BuildSystem/config/base.py",
line 97, in executeTest
     ret = apply(test, args,kargs)
   File
"/cygdrive/c/Downloads/src/petsc-dev/config/BuildSystem/config/packages/MPI.py",
line 703, in configureLibrary
     config.package.Package.configureLibrary(self)
   File
line 396, in configureLibrary
     for location, directory, lib, incl in self.generateGuesses():
   File
line 207, in generateGuesses
     d = self.checkDownload(1)
   File
line 316, in checkDownload
     return config.package.Package.checkDownload(self, requireDownload)
   File
line 284, in checkDownload
     return self.getInstallDir()
   File
line 170, in getInstallDir
     return os.path.abspath(self.Install())
   File
line 330, in Install
     return self.InstallMPICH()
   File
line 526, in InstallMPICH
     to specify the location of the installation when you rerun configure.')
