[petsc-dev] DESTDIR
Sean Farley sean at mcs.anl.gov
Fri Apr 23 11:35:14 CDT 2010
> This sounds like exactly the same issue as with RPATH.  If you have any
> location-specific info in the libraries, then "make shared" should RPATH
> the PREFIX despite installing to DESTDIR.  Apologies if this was obvious.
It is the exact same problem, I believe:
install_name_tool -rpath old new
via
http://developer.apple.com/mac/library/documentation/Darwin/Reference/ManPages/man1/install_name_tool.1.html
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100423/f5f355b8/attachment.html>
