[petsc-dev] DESTDIR
Sean Farley sean at mcs.anl.gov
Fri Apr 23 11:21:42 CDT 2010
> Essentially, yes.  The advantage of actually using pkgconfig is that
> autoconf, cmake, and others already have support for it.
True.
Actually, I'm almost done (once DESTDIR gets supported) with implementing a
Portfile for PETSc in MacPorts (which has the ability to have multiple
versions of packages installed), if anyone uses a mac and is interested in
that.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100423/afd3ca59/attachment.html>
