[petsc-dev] Fortran source format
Jed Brown jed at 59a2.org
Mon Apr 19 14:06:46 CDT 2010
On Mon, 19 Apr 2010 14:02:55 -0500, Sean Farley <sean at mcs.anl.gov> wrote:
> > if isGfortran450(): add '-Wno-line-truncation'
> But this is still a global setting. How about just having the flag for
> compiling petsc, not in the conf/variables?
The examples are the biggest offender (requiring long lines).  I think
users should get identical behavior when they copy the example somewher
and build with PETSc's makefiles.  This implies that the "global"
setting is correct.
Jed
