[petsc-dev] VecSqrt() for complex numbers?
Fri Apr 9 15:40:06 CDT 2010
   Suggest rename VecSqrt() to be VecSqrtAbs() and then in the future
if someone wants it they can add VecSqrt()?
    Barry
On Apr 9, 2010, at 3:37 PM, Jed Brown wrote:
> On Fri, Apr 9, 2010 at 13:34, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Should VecSqrt() for complex numbers take the square root of the
>> absolute
>> value (as it does for real numbers) or should be actually be the
>> square
>> root?
> I think it is critical that
>  VecSet(x,-1);
>  VecSqrt(x);
> means the same thing when compiled with real and complex.  If you want
> VecSqrt to actually do a square root instead of sqrt(abs(x)), then the
> above should generate an error with scalar-type=real, otherwise this
> different functionality needs to be a different function.
> Jed
