[petsc-dev] [petsc-maint #44162] Why do I always have to run 'conftest' on a batch system now?
Fri Apr 2 16:59:15 CDT 2010
   Satish,
     You changed the output of $PETSC_ARCH/conf/reconfigure*.py to
print one option for line, very readable!
     Could you please change the generation of reconfigure.py from
conftest (for the batch option) and the printing of initial configure
options in configure.log to do the one option for line please? They
are too hard to read for lots of options.
     Thanks
     Barry
On Apr 2, 2010, at 4:51 PM, Satish Balay wrote:
> --known-sizeof-MPI-Comm=4 --known-sizeof-MPI-Fint=4
> You have typos here. Since some options are missing - configure will
> generate a conftest file.
> Note: think of the generated reconfigure.py or
> reconfigure_PETSC_ARCH.py as something you can use as your initial
> script. [with a bit of edits to pretty up and remove absolute paths]
> Satish
> On Fri, 2 Apr 2010, Richard Tran Mills wrote:
>> Hi Folks,
>> It seems that for some time (I know Glenn complained about this a
>> while ago),
>> I have been having to run the 'conftest' file that configure.py
>> generates for
>> me on Jaguar to get a reconfigure.py that lets me do the actual
>> configuration.
>>  This is despite the fact that I believe I have everything that
>> conftest
>> finds out already specified in my configure.py command.  It used to
>> be the
>> case that I could just make sure all of this stuff got passed to
>> configure,
>> and it would not generate the conftest executable for me.  Can
>> someone tell me
>> what I am missing?
>> configure.log and the generated reconfigure.py are attached.
>> Thanks,
>> Richard
