ML symbols in petscksp.so
Wed Oct 28 16:29:48 CDT 2009
   We do do this for Mac (libpetsc*.dylib) and I think it mostly
works. But I am not aware of anyone doing this intentionally for PETSc
on Linux (though I think it is a good idea if it can be done).
    Bartry
On Oct 28, 2009, at 4:27 PM, Matthew Knepley wrote:
> > You always have to link the ML library if you configure for ML,
> right?
> No, all the third party libs used to be put into the PETSc shared libs
> (but not the static libs).  The easiest way to do this is with
> -Wl,--whole-archive though I haven't looked at the build system to see
> if this is how it is actually being done.  All the others still behave
> this way, but ML is no longer included.
> Wenever did this, and satill don't. We use -rpath, so that you can
> track back to
> the associated shared library, if it exists.
>   Matt
> So if you are using shared libs, you only need to link libpetsc*.so.
> This is recommended practice with shared libs, you only explicitly
> link
> the interface libraries (those that your code actually calls into) and
> let the linker handle the dependencies.  Of course when using static
> libs, you need to explicitly link all the dependencies.
> Jed
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
