person who wrote PetscRandomGetValueReal() PetscRandomGetValueImaginary()
Fri Oct 23 15:14:28 CDT 2009
On Oct 23, 2009, at 2:33 PM, Matthew Knepley wrote:
> On Fri, Oct 23, 2009 at 2:31 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   I thought I was working on builder.py? Crude, yes, but the way I
> want it :-).
>   Were you adding code to builder.py?
> Yep. I am all for this. However, two people on such a small piece of
> code is hard.
> Also, didn't you ask me to put that stuff in?
    Sorry I must have miscommunicated. I thought you were finished
when you added the basic code that could compile some .c code (that's
what I wanted from you, since that required knowledge of the
particular configure objects and variables to get out the compiler,
the compiler flags etc.). So I started working on it. I didn't expect
that you would keep on working on it.
    If they are like totally different, maybe you should rename yours
builder2.py (not try to merge) and then we can decide how to proceed.
(for example, toss mine, toss yours, or I could pick chunks of yours
that I like).
   Barry
>   Matt
>   Barry
> On Oct 23, 2009, at 2:26 PM, Matthew Knepley wrote:
> Done.
> However, Igot an unholy merge on builder.py. It is definitely
> screwed up. I can fix it when
> I get home on Sunday.
>  Matt
> On Fri, Oct 23, 2009 at 2:07 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>  PetscRandomGetValueReal() and PetscRandomGetValueImaginary() have
> no mention in their manual pages what they do?
> Do they return random numbers with a zero imaginary part and a zero
> real part respectively? Manual page does not see.
> Also PetscRandomGetValue() does not have .seealso to these two
> functions, nor do these two functions have .seealso to the other.
>  Whoever wrote these things please fix this.
>  Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
