Subsecond sleep
Fri Oct 16 11:27:00 CDT 2009
   It is fine with me to switch the infrastructure to use a PetscReal
instead of integer
   Barry
On Oct 16, 2009, at 5:02 AM, Jed Brown wrote:
> I sometimes want to slow down animation with a small problem size and
> -draw_pause is generally does what I want, but it can only take
> integer
> arguments and pausing for a whole second every time is often too much.
> There are subsecond sleep functions (like usleep and nanosleep) in
> POSIX, and I've rolled my own micro-sleep command-line option more
> than
> once now.  Is there a compelling reason not to make -draw_pause and
> PetscSleep take a real value, thus offering higher resolution when
> it is
> available?
> Jed
