PETSC_ARCH variable --> PETSC_CONF
Boyana Norris norris at mcs.anl.gov
Mon Nov 30 16:38:20 CST 2009
Actually GNU make features are the only reason I continue to touch
make -- without them I would not use it for anything.
Boyana
Boyana Norris, Computer Scientist, Argonne National Laboratory
norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
On Nov 30, 2009, at 4:29 PM, Barry Smith wrote:
>  Boyana,
>    We are going to stop using make before we ever start using GNU
> make features :-)
>   Barry
> On Nov 30, 2009, at 4:23 PM, Boyana Norris wrote:
>> On Nov 30, 2009, at 3:59 PM, Barry Smith wrote:
>>> On Nov 30, 2009, at 3:51 PM, Boyana Norris wrote:
>>>> Why not recognize both? It's fairly trivial to check for
>>>> PETSC_CONF if PETSC_ARCH is undefined and internally define
>>>> PETSC_ARCH using PETSC_CONF.
>>> This is a make variable. I am not sure that it is trivial to check
>>> if a variable is set and use something else otherwise in a tidy
>>> way in make. Plus I had the idea of having two variables that mean
>>> the same thing.
>> There are a couple of different ways, e.g., one is
>> ifndef PETSC_ARCH
>> ifdef PETSC_CONF
>> PETSC_ARCH=$(PETSC_CONF)
>> else
>> $(error "Make sure the PETSC_CONF environment variable is defined
>> before running make.")
>> endif
>> endif
>> This is for GNU make, which is pretty widely available, and may
>> have to be adjusted for ancient systems.
>> Boyana
>>> Barry
>>>> Boyana
>>>> ~norris/
>>>> On Nov 30, 2009, at 3:43 PM, Matthew Knepley wrote:
>>>>> On Mon, Nov 30, 2009 at 3:38 PM, Barry Smith
>>>>> <bsmith at mcs.anl.gov> wrote:
>>>>> I guess the argument is that on occasion in the future a certain
>>>>> number of people will misinterpret the meaning of PETSC_ARCH
>>>>> frustrating them and us; the number misinterpreting PETSC_CONF
>>>>> will be much smaller or zero saving people's time and energy.
>>>>> This will be far outweighed by the number of people complaining
>>>>> about such a change. I agree with them.
>>>>> Matt
>>>>> Barry
>>>>> On Nov 30, 2009, at 3:25 PM, Matthew Knepley wrote:
>>>>> I see the point, but this is one of the oldest parts of PETSc,
>>>>> and I am hesitant to change one
>>>>> arbitrary name to another without a more convincing reason.
>>>>> Matt
>>>>> On Mon, Nov 30, 2009 at 2:17 PM, Barry Smith
>>>>> Lisandro has pointed out to me several times that the variable
>>>>> name PETSC_ARCH can be confusing; some people may think it is
>>>>> related to the architecture of the machine and don't understand
>>>>> that it is an arbitrary name that the user can make up. He
>>>>> suggested changing it to PETSC_CONF to be clearer.
>>>>> Should we change it? Use something else?
>>>>> Barry
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to
>>>>> which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> -- Norbert Wiener
