PETSC_ARCH variable --> PETSC_CONF
Boyana Norris norris at mcs.anl.gov
Mon Nov 30 16:23:28 CST 2009
On Nov 30, 2009, at 3:59 PM, Barry Smith wrote:
> On Nov 30, 2009, at 3:51 PM, Boyana Norris wrote:
>> Why not recognize both? It's fairly trivial to check for PETSC_CONF
>> if PETSC_ARCH is undefined and internally define PETSC_ARCH using
>> PETSC_CONF.
>  This is a make variable. I am not sure that it is trivial to check
> if a variable is set and use something else otherwise in a tidy way
> in make. Plus I had the idea of having two variables that mean the
> same thing.
There are a couple of different ways, e.g., one is
ifndef PETSC_ARCH
  ifdef PETSC_CONF
   PETSC_ARCH=$(PETSC_CONF)
  else
   $(error "Make sure the PETSC_CONF environment variable is defined
before running make.")
  endif
endif
This is for GNU make, which is pretty widely available, and may have
to be adjusted for ancient systems.
Boyana
>  Barry
>> Boyana
>> Boyana Norris, Computer Scientist, Argonne National Laboratory
>> norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
>> On Nov 30, 2009, at 3:43 PM, Matthew Knepley wrote:
>>> On Mon, Nov 30, 2009 at 3:38 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>  I guess the argument is that on occasion in the future a certain
>>> number of people will misinterpret the meaning of PETSC_ARCH
>>> frustrating them and us; the number misinterpreting PETSC_CONF
>>> will be much smaller or zero saving people's time and energy.
>>> This will be far outweighed by the number of people complaining
>>> about such a change. I agree with them.
>>>  Matt
>>>  Barry
>>> On Nov 30, 2009, at 3:25 PM, Matthew Knepley wrote:
>>> I see the point, but this is one of the oldest parts of PETSc, and
>>> I am hesitant to change one
>>> arbitrary name to another without a more convincing reason.
>>>  Matt
>>> On Mon, Nov 30, 2009 at 2:17 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> Lisandro has pointed out to me several times that the variable
>>> name PETSC_ARCH can be confusing; some people may think it is
>>> related to the architecture of the machine and don't understand
>>> that it is an arbitrary name that the user can make up. He
>>> suggested changing it to PETSC_CONF to be clearer.
>>> Should we change it? Use something else?
>>>   Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
>>> -- Norbert Wiener
