__builtin_expect with other compilers
Jed Brown jed at 59A2.org
Mon Nov 30 06:49:40 CST 2009
I noticed that GCC mispredicts the conditional in CHKERRQ.  At high
optimization levels it still relocates most of the PetscError call, but
the non-error path is cleaner with
  #define CHKERRQ(n) if (UNLIKELY(n)) {return PetscError(__LINE__,__FUNCT__,__FILE__,__SDIR__,n,0," ");}
where the following definitions are typical
  #define UNLIKELY(c) __builtin_expect(!!(c),0)
  #define LIKELY(c)   __builtin_expect(!!(c),1)
I'm not familiar with the analogues for other compilers.  I don't
suggest cluttering the code with such hints, but just putting it in
CHKERRQ would decrease code size for the non-error path which seems like
a good thing.
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091130/9efda629/attachment.sig>
