Why did you removed PETSC_ARCH_NAME variable in makefiles?
Jose E. Roman jroman at dsic.upv.es
Wed Nov 25 12:39:45 CST 2009
Barry,
I think the use of PETSC_ARCH_NAME is motivated by a request I sent in
December last year, see http://lists.mcs.anl.gov/pipermail/petsc-dev/2008-December/001120.html
We use it when configuring SLEPc with a prefix-based PETSc. If you
remove this variable, we will have to think about an alternative way
of supporting that case.
Jose
On 25/11/2009, Barry Smith wrote:
>  Lisandro,
>     That change will certainly NOT be reverted. PETSC_ARCH_NAME!
> what the heck kind of variable name is that?
>     I need to understand the reason for PETSC_ARCH_NAME, then we can
> come up with some solution. What is the difference between
> PETSC_ARCH_NAME and PETSC_ARCH? Is it only needed when --prefix is
> used (so PETSC_ARCH does not exist), if so, exactly why is it
> needed, the whole idea behind --prefix is to eliminate PETSC_ARCH,
> so why is it needed? How is PETSC_ARCH_NAME used?
>  Barry
> On Nov 25, 2009, at 10:14 AM, Lisandro Dalcin wrote:
>> Barry, an outcome of the two changesets below:
>> changeset:   14451:b289577caf8f
>> user:        barrysmith at bsmith-laptop.mcs.anl.gov
>> date:        Mon Oct 19 16:31:16 2009 -0500
>> summary:     update to install.py to ONLY use RDict.db (and not
>> command line)
>> changeset:   14383:447d34bd2d4b
>> date:        Thu Oct 08 16:33:59 2009 -0500
>> summary:     finished cleaning up makefiles, moved charactoristic.h
>> to
>> include location standard place where it is easy to use
>> was that these two lines in config/PETSc/utilities/arch.py were
>> removed:
>>   # SLEPc configure need this info
>>   self.addMakeMacro('PETSC_ARCH_NAME',self.arch)
>> SLEPc and petsc4py/slepc4py/tao4py relies on this variable being
>> defined in makefiles. There is now a new way to get the original name
>> of the build-time $PETSC_ARCH? If not, any chance this change could
>> be
>> reverted?
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
