Should PetscObjectName be collective?
Wed Nov 18 09:27:59 CST 2009
On Nov 18, 2009, at 8:52 AM, Jed Brown wrote:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ecbd2dcad71a
> Note that there are a couple other places where keyvals are created
> (with no way to free them).  Does it make sense to put those fields
> into this one?
> Is there a reason that petscinitialize_() duplicates much of
> PetscInitialize()?  Seems like we ought to have the common stuff in a
> PetscInitialize_Private().
    There was a reason for this duplication many years ago. I do not
know if it is still needed. There is the business of the fortran
"initialization" being done twice which may be fragile. You could try
merging but test it relentlessly :-)
    Barry
> Jed
