Should PetscObjectName be collective?
Tue Nov 17 17:46:52 CST 2009
On Nov 17, 2009, at 5:08 PM, Jed Brown wrote:
> Lisandro Dalcin wrote:
>> On Mon, Nov 16, 2009 at 4:04 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>>> Ok, we could just put the "counter" into the MPI attribute and
>>> then just
>>> have uniqueness of the names within each communicator.  This would
>>> solve
>>> Jed's problem cleanly.
>> I agree. +1 on this.
> If I understand correctly, every communicator would start at 0 with no
> attempt to distinguish communicators.  PetscObjectName would add an
> attribute to each communicator it sees.
    Nope, don't want to do it this way, it increases the complexity.
See below.
> Browsing tagm.c,
> MPI_Keyval_free is never called for the other attributes.  This
> explains
> some valgrind warnings under Open MPI but not under MPICH (presumably
> MPICH frees zombie keyvals in MPI_Finalize() but OMPI does not).
    We should refactor the code to move the body of the code block
below into  PetscIntialize()
   if (Petsc_Tag_keyval == MPI_KEYVAL_INVALID) {
     ierr =
MPI_Keyval_create(MPI_NULL_COPY_FN,Petsc_DelTag,&Petsc_Tag_keyval,
(void*)0);CHKERRQ(ierr);
     ierr =
MPI_Keyval_create
(MPI_NULL_COPY_FN,Petsc_DelComm,&Petsc_InnerComm_keyval,
     ierr =
MPI_Keyval_create
(MPI_NULL_COPY_FN,Petsc_DelComm,&Petsc_OuterComm_keyval,
and put a corresponding set of frees() into PetscFinalize().
>  I see
> that Petsc_InnerComm_keyval and Petsc_OuterComm_keyval just uses the
> pointer to hold the value, since the counter changes we need to
> actually
> malloc.
> Do we want the counter to hold a reference count (and be shared across
> MPI_Comm_dup)?
     No, we don't want to share across MPI_Comm_dup(). They are
different communicators so should have their own name counters. Note
that it would be rare that there are MPI_Comm_dup()s lying around
anyways unless the user explicitly calls it.
> This is slightly tricky because it's not normally
> obvious to a user when a duplication occurs, but the numbering would
> be
> different if the comm was duped before or after the attribute was set
> (unpredictable if it's set in PetscObjectName()).  OTOH,
> PetscCheckSameComm will say duped communicators are equivalent so we
> really have to share the counter.  I'm talking myself into starting a
> reference-counted counter the first time PETSc touches a communicator.
    I am not sure what reference counting you are talking about but
PETSc currently reference counts how many objects reference a
communicator attribute (this is tagvalp[1]).  When it gets down to
zero it deletes the attribute and the inner communicator.
    To get a counter for object names you can increase the size of
tagvalp[2] to tagvalp[3], then each time you get a name crank the
value up by 1, much like PetscCommGetNewTag() No need to add new
attributes.
   Barry
> Jed
