-malign-double
Jed Brown jed at 59A2.org
Mon Nov 16 14:50:04 CST 2009
Satish Balay wrote:
> The whole reason for having PetscMalloc2() PetscMalloc3() etc is to
> reduce the number of calls to malloc() - thus hoping for a performance
> boost.
> For one - this usage was triggered by old SunOS boxes [where malloc
> took a long time]. We don't know if this is still true for any of the
> current OSes.
> With the increased complexity of managing alignment here - is it still
> worth keeping these merged mallocs? [do we still get any payoff from
> this complexity? - instead of relying directly on malloc() for the
> necessary alignment?]
I agree with Barry that the macros are good even if they were always
doing separate macros underneath, it's much easier to see what is
allocated together, and I frequently look for the PetscFree6 that must
be associated with the PetscMalloc6 I'm looking at.
Here are some benchmarks.  In the following, I compare doing four
mallocs in each loop (calling malloc directly) and doing a single malloc
(and fixing up alignment).  If there is nothing between the malloc and
free, we get
  malloc4 1000000 loops in 1412541359 cycles, average 1412.541359
  malloc1 1000000 loops in 298137728 cycles, average 298.137728
If there is an extra allocation between malloc and free, we get
  malloc4 1000000 loops in 1667959560 cycles, average 1667.959560
  malloc1 1000000 loops in 538137819 cycles, average 538.137819
Clearly glibc is optimized for freeing the very last thing allocated.
Fixing the alignment takes only a couple cycles.
Remarkably, these results are reproducible to 6 significant figures or
so.  BTW, should we put PAPI support into PETSc, it no longer needs
kernel patches with 2.6.31.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091116/7060fe2e/attachment.sig>
