[petsc-maint #37691] problem with petsc4py
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 16 12:26:58 CST 2009
On Mon, Nov 16, 2009 at 4:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 16, 2009, at 9:37 AM, Lisandro Dalcin wrote:
>> On Sat, Nov 14, 2009 at 12:36 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  petsc-dev should be setup to always use the appropriate petsc4py so this
>>> shit works automatically.
>> However, please note that I cannot guarantee that petsc4py-dev will be
>> in sync with latest changes in petsc-dev. Sometimes, a delay of a week
>> or so should be expected.
>   This we understand.
>>> $ hg clone http://petsc.cs.iit.edu/petsc4py/petsc4py-dev
>   So the only thing holding us up is having Matt add support for using hg to
> download in BuildSystem. There was support for bk but hg was never added.
>   Matt, can you add this?
IIRC, there were issues about that a URL like
"http://petsc.cs.iit.edu/petsc4py/petsc4py-dev" provides no clue about
the repo being a Mercurial one. However, I want to mention a
"convention" it is being used elsewere (see for example:
http://pip.openplans.org/#requirements-files)...  Basically, you have
to prefix the URL like this:
"hg+http://petsc.cs.iit.edu/petsc4py/petsc4py-dev".. then the hg+ svn+
git+ bzr+ prefix provides the required clue.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
