-malign-double
Sat Nov 14 20:30:12 CST 2009
On Nov 14, 2009, at 4:01 PM, Lisandro Dalcin wrote:
> On Fri, Nov 13, 2009 at 11:09 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>   Good point, I have removed it.
>>   I put it in because I wanted an easy way to test that PETSc
>> double arrays
>> are always 8 byte aligned (and the unaligned struct values were
>> giving me
>> lots of false alarms).
>>   I guess we can test for double align on x86_64 systems.
>>   Barry
>> The IBM BlueGene doesn't like 4 byte aligned doubles and sends a
>> bus error
>> after a certain number are generated, Thus I was motivated to make
>> PETSc a
>> bit clearer on that.
> But then the compiler in the BlueGene does not -malign-double by
> default? That would be weird and annoying...
    BlueGene has two compilers, IBM's XLc and gcc. I do not know if
either of them are rigged to 8 byte align by default.
   Barry
>> On Nov 12, 2009, at 9:29 AM, Lisandro Dalcin wrote:
>>> On Wed, Nov 11, 2009 at 11:02 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>>  Satish,
>>>>   gcc supports the option  -malign-double on some systems. Please
>>>> add it
>>>> to
>>>> the flags that configure checks for c and c++ and have it added
>>>> if it
>>>> exists.
>>> Definitely -1. Why are you asking for this? On x86_64 this is the
>>> default. In i386, this flag is likely going to break ABI's.
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>> (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
