[PETSC #19456] PETSc with blocksolve95 and matlab interface
Matthew Knepley petsc-maint at mcs.anl.gov
Tue May 19 13:59:27 CDT 2009
I vote for kicking out BlockSolve95. It has not been maintained since 95. It
does parallel
ICC(0) and ILU(0). The ILU can be done by PILUT. It appears the only thing
we give up
is ICC(0) in parallel. IS this worth keeping this headache?
  Matt
On Tue, May 19, 2009 at 1:25 PM, Satish Balay <petsc-maint at mcs.anl.gov>wrote:
> On Tue, 19 May 2009, Rebecca Hartman-Baker wrote:
> > Hi,
> > I'm installing PETSc 3.0.0 p4 on jaguar at ORNL, which runs linux on the
> > front end and CNL 2.1 on the compute nodes.  Our MPI is the Cray
> > distribution.  I am compiling with PGI compiler 8.0.3.  The user
> requested
> > that I create an installation that includes hdf5, hypre, sundials,
> > blocksolve95, and the matlab interface.  In creating this custom
> > installation, I'm running into two problems.
> > First, I was having some trouble figuring out how to get blocksolve95.
>  When
> > I click on the links in the PETSc website referencing blocksolve95, I get
> a
> > "page not found" error.  After asking a colleague about it, I was able to
> > track down the ftp site to retrieve it (
> ftp.mcs.anl.gov/pub/BlockSolve95/),
> > but this is one of the few packages where there's an interface to it but
> no
> > means for PETSc to download and install it for you.  I wanted to make
> sure
> > that since there doesn't appear to be an official source that I've indeed
> > fetched the right thing.
> Yes - we don't have a --download-blocksolve95 option. It has to be
> installed manually - and then specified to PETSc
> configure. [BlockSolve uses very-old install style of petsc - and was
> never updated..]
> > Second, when I compile the matlab interface, it appears that there's an
> > invalid flag, -pthread, which is not understood by the PGI compiler.  It
> > appears to be a standard GNU flag that allows the use of pthreads.  I
> wasn't
> > able to track down where this flag is set.  Other than this, the
> compilation
> > (without blocksolve95) went just fine.  The logfiles told me to send them
> to
> > you, so attached please find make.log and configure.log from my
> compilation.
> libfast in:
> /sw/xt5/petsc/3.0.0/cnl2.1_pgi8.0.3_custom/petsc-3.0.0-p4/src/sys/viewer/impls/socket/matlab
> BEGINNING TO COMPILE MATLAB INTERFACE
> /opt/cray/xt-asyncpe/2.3/bin/cc: INFO: linux target is being used
> pgcc-Error-Unknown switch: -pthread
>    mex: link of ' "sread.mexa64"' failed.
> make[10]: [sread] Error 1 (ignored)
> /bin/mv: cannot stat `sread.mex*': No such file or directory
> The errors are from /sw/xt5/matlab/7.7/sles_binary/bin/mex - as we are
> attempting to invoke it with "mex CC=cc" - but perhaps it only works
> with "mex CC=gcc"?
> Perhaps you can edit src/sys/viewer/impls/socket/matlab/makefile - and
> remove all occurences of "CC=${CC}" - and see if it works.
> Satish
> > Thanks for your help!
> > Sincerely,
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090519/de8d49dc/attachment.html>
