TS_RK enhancements
Mon May 18 14:36:01 CDT 2009
On May 15, 2009, at 11:07 PM, Kai Germaschewski wrote:
> On Thu, May 14, 2009 at 3:36 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   There is no one who is coordinating the TS interface at the
> moment. So you are welcome to propose changes/fixes/improvements and
> are in as good as a position as any of us.
>   I see there are four methods: prestep, poststep, update,
> postupdate; as you noticed the naming and usage of them is a bit
> inconsistent. Even the TSStep() function has a confusing name since
> it actually takes (potentially) many steps.  I suggest starting the
> following possible changes.
>   change TSStep to TSSolve(),
> Yup, that makes a lot of sense. Actually, there is a TSSolve()
> already, which however seems rarely used (all of the examples use
> TSStep())
>   move the prestep() and poststep() methods to be the ones used AT
> the beginning and end of each timestep (not called in TSSolve())
> Agreed. I don't really like changing the behavior of functions while
> keeping the name the same, but I'll just assume there are few users
> of the current PreStep / PostStep, since they don't really make much
> sense.
    Get use to it. I am perfectly willing to admit the old design was
wrong. PETSc users just have to bite the bullet on this and they are
willing too.
>   eliminate update() and postupdate() confusing names anyways
>   determine if there is a need for a pre and post called in
> TSSolve() could call them presolve and postsolve if you put them in.
> I don't think there's a need for a user-settable presolve/postsolve,
> because if they want to call functions before / after calling
> TSSolve(), they can just call them directly. There may well be good
> reasons to introduce methods like this into TS that can be set by a
> specific implementation (like euler/beuler/...) to simplify the code
> there.
    Good point; maybe the presolve/postsolve are not needed.
> do we really want prestep and poststep deciding to kick out of the
> iteration or do we want yet another method (corresponding to the
> converged() method in KSP and SNES) that is used to exit early from
> the solver?
>   I think using a flag to exit early from the solver is better than
> setting dt to zero.
> A new method seems like a much cleaner way, and would avoid breaking
> the existing method by changing the call sequence. Now the next
> question is for a good name. In some sense, "SetConvergenceTest" is
> nice because it's the same as used elsewhere, but it really doesn't
> quite describe what it really does here. So how about
> "SetTerminationTest"?
    Sounds ok to try.
>   having the steps and ptime output arguments from TSSolve() I think
> is wrong. They should be kept in the TS object and then calls like
> TSGetSolveTime() and TSGetNumberSteps()
>   to access them.
> I'm not sure what you're referring to. For TSMonitor(), I don't
> think there's a good reason to change the calling sequence. For
> TSStep() -> TSSolve(), I definitely agree, TSSolve() shouldn't
> return those values. I think the TSSolve(TS ts, Vec sol) interface
> as it already exists is just fine.
    I was referring to the steps and ptime arguments to TSStep(), but
since TSStep() is going way then this is no big deal.
> There's already TSGetTime() and TSGetTimeStepNumber(), which can be
> used to do the above. They don't have the most elegant names, but I
> think we both believe that one shouldn't have multiple names for the
> same functionality, and I personally don't like renaming functions
> just for aesthetics because it's a pain to change applications and
> destroy backwards compatibility. (but past experience makes me think
> that the petsc developers look at this differently... ;)
    Absolutely
> My transition plan looks like this:
> - Integrate the current TSStep() into TSSolve() and remove TSStep
> from the public interface (which requires
> changing current users of TSStep()
    Yes, I think TSStep() should not exist at all, even in a private
method.
> - Rename the TSStep_* methods -> TSSolve_*
> - Add a generic TSSolve_TSStep() function, that provides a default
> timeloop implementation so that simple timestepping methods only
> have to implement a new TSStep_* method which does one (complete)
> step, but the actual looping, bookkeeping etc is handled by generic
> code. This could end up being an interface much like what Lisandro
> has to python. On the other hand, more complicated time integrators
> could take full control of the entire integration. (If it turns out
> there are no users left for such an interface, there may be no point
> in keeping it)
    I don't see a having a TSSolve_TSStep() default as a good idea. I
would just have a separate loop for each integration technique and not
try to get reuse between different integrators.
> So actually I came across one point I'm wondering:
> All current time steppers seem to do
> VecCopy(sol, update);
> while (!done) {
>   FindSolutionAtNewTime(update);
>   VecCopy(update,sol);
> Obviously for methods where steps may fail and will be retried, it's
> necessary to preserve the old solution, however
> many schemes just call KSPSolve(.., update) or SNESSolve(...,
> update). In a linear method, I suppose by definition the operator
> does not depend on the current "sol". In a nonlinear problem, it
> will, however I suppose that SNESSolve() wouldn't update the
> solution vector until the very end, or am I missing something?
> Point being, all these VecCopy()'s aren't really necessary and
> actually end up making the code a bit more complicated than needs
> be, and obviously aren't helping performance. (For implicit methods,
> those copies will generally be negligible, but for the explicit ones
> (euler eg), that's not so clear...)
> --Kai
> Kai Germaschewski
> Assistant Professor, Dept of Physics / Space Science Center
> University of New Hampshire, Durham, NH 03824
> office: Morse Hall 245F
> phone:  +1-603-862-2912
> fax: +1-603-862-2771
