SNESSetUp() and matrix-free options
Lisandro Dalcin dalcinl at gmail.com
Mon May 11 14:46:31 CDT 2009
On Fri, May 8, 2009 at 3:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Quick look is ok for me.
Just a note, to put it clear. With my patch, passing both "-snes_mf
-snes_mf_operator" is valid, and equivalent to just passing
"-snes_mf_operator" ...
>  Barry
> On May 8, 2009, at 1:39 PM, Lisandro Dalcin wrote:
>> Well, it was not so easy to change the options name...
>> We would need to update docs, tests, tutorial examples, and at this
>> point it is not clear if we could agree on better options names...
>> I'm now following a different approach, hope the diff attached make it
>> clear enough... Just take a look to changes to SNESSetFromOptions()
>> On Thu, May 7, 2009 at 10:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  How about?
>>>  -snes_mf   (means what it currently means)
>>>  -snes_mf operator (means what -snes_mf_operator means)
>>>  Barry
>>> On May 7, 2009, at 6:03 PM, Lisandro Dalcin wrote:
>>>> On Thu, May 7, 2009 at 6:14 PM, Jed Brown <jed at 59a2.org> wrote:
>>>>> Barry Smith wrote:
>>>>>>  I understand this. I just don't view this as a big deal worth
>>>>>> changing the code over.
>>>>> I agree.  My comment was that *if* the options were to be changed, as
>>>>> Lisandro was suggesting, then it would be better to eliminate
>>>>> unnecessary options conflicts.
>>>> Well, now that I'm actually writing the code, things are a bit more
>>>> clear...
>>>> perhaps we should have just two options
>>>> 1) -snes_mf, if passed, should be string "full" or "operator" (not
>>>> sure about these)
>>>> 2) -snes_mf_version, if passed, should be integer 1 or 2
>>>> In Python pseudocode (thinking options like a Python dict)
>>>> if "snes_mf" in options:
>>>>  version = options.get("snes_mf_version", 1)
>>>>  if version == 1:
>>>>    MatCreateSNESMF(...)
>>>>  elif version == 2:
>>>>    SNESDefaultMatrixFreeCreate2(...)
>>>>  else:
>>>>    raise PetscError
>>>>  value = options["snes_mf"]
>>>>  if value == "operator":
>>>>    SNESSetJacobian(J,0,0,...)
>>>>  elif value == "full":
>>>>    SNESSetJacobian(J,J,MatMFFDComputeJacobian)
>>>>  else:
>>>>    raise PetscError
>>>> Note that I expect snes_mf_version=2 (despite being MatShell based) to
>>>> work with snes_mf="operator"
>>>> What do you think?
>>>> Lisandro Dalcín
>>>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>>>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>> Tel/Fax: +54-(0)342-451.1594
>> Lisandro Dalcín
>> <snes.diff>
Lisandro Dalcín
