Unsure about some entries in log_summary for 2B DoF problem
Mon May 4 14:00:56 CDT 2009
On May 4, 2009, at 1:51 PM, Richard Tran Mills wrote:
> Barry,
> Is there a way to dump the log data for all processes so that I can
> do things like look at the the time spent in each stage by each
> process?  I thought you or someone else had mentioned adding a
> capability to do this in PETSc to a file format that would be easy
> to manipulate using something like Python... but perhaps I recall
> incorrectly.
   Hong has worked a little on this, you are welcome to mess with it
if you want (Hong, have you pushed this?).
    Barry
> It would be very nice to have this to calculate some more detailed
> statistics.
> --Richard
> Barry Smith wrote:
>>   Matt is completely correct. What this means is that though some
>> processes wait a long time for the dots, MOST processes don't wait
>> much at all.
>> In other words, the dot causes very little idle time integrated
>> over the whole machine.
>> Meanwhile for flow (where the percentage is large) the dots cause a
>> LARGE amount of idle time integrated over the machine.
>> Why it is high for one and not the other I do not know.
>>   Barry
>> On May 4, 2009, at 1:09 PM, Matthew Knepley wrote:
>>> I believe that the time reported there is collective sum of times
>>> divided by the collective sum
>>> of the stage times. If you look at the time imbalance, it is a
>>> staggering 9.7, which either means
>>>  1) The partition is really crap (which we know isn't true)
>>>  2) Some procs spend a lot of time waiting
>>> We can get at this waiting time with the split VecDot() events.
>>>  Matt
>>> On Mon, May 4, 2009 at 12:58 PM, Richard Tran Mills <rmills at climate.ornl.gov
>>> > wrote:
>>> PETSc folks,
>>> I was looking over the log summary data for the 2 billion degrees
>>> of freedom transport problem, and I'm a bit puzzled by some of the
>>> things I'm seeing.  (I sent a tarball of this to the pflotran-dev
>>> list on April 30.)  For instance, looking at the run at 32768
>>> cores, I see that the total time for the "transport" phase is
>>> 3.2139e+02 seconds.  But if I look at the VecDot line for the
>>> transport stage, I see
>>> Event                Count      Time (sec)     Flops   --- Global
>>> ---  --- Stage ---   Total
>>>                  Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
>>> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>> VecDot              1306 1.0 4.1529e+01 9.7 1.76e+08 1.1 0.0e+00
>>> 0.0e+00 1.3e+03  1  0  0  0  1   3  0  0  0 24 128305
>>> It's hard to read this the way my email client will wrap it, but
>>> it's saying that 3% of the time in the stage was spent on
>>> VecDot()s.  But the max time in VecDot is 4.1529e+01, close to
>>> thirteen percent.  Does the "%T" for the stage mean something
>>> other than what I think it does?
>>> --Richard
>>> Richard Tran Mills, Ph.D.            |   E-mail: rmills at climate.ornl.gov
>>> Computational Scientist              |   Phone:  (865) 241-3198
>>> Computational Earth Sciences Group   |   Fax:    (865) 574-0405
>>> Oak Ridge National Laboratory        |   http://climate.ornl.gov/~rmills
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
