Unsure about some entries in log_summary for 2B DoF problem
Mon May 4 13:46:58 CDT 2009
    Matt is completely correct. What this means is that though some
processes wait a long time for the dots, MOST processes don't wait
much at all.
In other words, the dot causes very little idle time integrated over
the whole machine.
Meanwhile for flow (where the percentage is large) the dots cause a
LARGE amount of idle time integrated over the machine.
Why it is high for one and not the other I do not know.
    Barry
On May 4, 2009, at 1:09 PM, Matthew Knepley wrote:
> I believe that the time reported there is collective sum of times
> divided by the collective sum
> of the stage times. If you look at the time imbalance, it is a
> staggering 9.7, which either means
>   1) The partition is really crap (which we know isn't true)
>   2) Some procs spend a lot of time waiting
> We can get at this waiting time with the split VecDot() events.
>   Matt
> On Mon, May 4, 2009 at 12:58 PM, Richard Tran Mills <rmills at climate.ornl.gov
> > wrote:
> PETSc folks,
> I was looking over the log summary data for the 2 billion degrees of
> freedom transport problem, and I'm a bit puzzled by some of the
> things I'm seeing.  (I sent a tarball of this to the pflotran-dev
> list on April 30.)  For instance, looking at the run at 32768 cores,
> I see that the total time for the "transport" phase is 3.2139e+02
> seconds.  But if I look at the VecDot line for the transport stage,
> I see
> Event                Count      Time (sec)     Flops   --- Global
> ---  --- Stage ---   Total
>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> VecDot              1306 1.0 4.1529e+01 9.7 1.76e+08 1.1 0.0e+00 0.0e
> +00 1.3e+03  1  0  0  0  1   3  0  0  0 24 128305
> It's hard to read this the way my email client will wrap it, but
> it's saying that 3% of the time in the stage was spent on
> VecDot()s.  But the max time in VecDot is 4.1529e+01, close to
> thirteen percent.  Does the "%T" for the stage mean something other
> than what I think it does?
> --Richard
> Richard Tran Mills, Ph.D.            |   E-mail: rmills at climate.ornl.gov
> Computational Scientist              |   Phone:  (865) 241-3198
> Computational Earth Sciences Group   |   Fax:    (865) 574-0405
> Oak Ridge National Laboratory        |   http://climate.ornl.gov/~rmills
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
