MatMult_Scatter woes
Jed Brown jed at 59A2.org
Tue Mar 31 08:31:55 CDT 2009
On Mon 2009-03-30 21:28, Barry Smith wrote:
> On Mar 30, 2009, at 7:48 PM, Matthew Knepley wrote:
>> On Mon, Mar 30, 2009 at 6:13 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>>   I don't think square has anything to do with it. It depends on
>> whether all the entries in y[i] are hit or if some are skipped, this
>> depends exactly on the scatter.
>>   The first time the mult is called, duplicate x and y temporarility,
>> fill a xdup with all 1s. Do the scatter, locate all entries of ydup
>> that are zero, keep a list of these.
>> destroy xdup, ydup.
>>   Now do the MatMult() by zeroing all the entires in the list and then
>> do the scatter, now you have an efficient and correct MatMult. The
>> drawback of course is the setup time, but in fact that cost is only one
>> scatter (MatMult()) so is likely worth it.
>>  One could do a similar setup for the transpose?
>> I must misunderstand you. The problem above is that INSERT_VALUES is
>> used, but when two input locations
>> map to the same output location, they should be added.
>  No, when two map to the same output the scatter is not well defined and
> hence the multiply is not defined.
> When building the scatter we could check for multiple inputs going to
> the same output but we don't, it will end up
> just putting one value in and then the other and depending on the order
> of the message passing it could be different.
There are two issues, the output index set may be not be injective
(multiple inputs map to the same output) or the output index set may not
be surjective (not every entry of the output vector is hit).
When the output index set is not injective, the scatter is ill-defined
with INSERT_VALUES, but is well-defined with ADD_VALUES.  It is not okay
to disallow such scatters, the transpose of the global-to-local scatter
(_p_DA::gtol) is necessarily this way.
The (forward) scatter is well-defined with INSERT_VALUES if (and only
if) ymax <= 1 after
  VecSet(x,1);
  VecSet(y,0);
  VecScatterBegin(scat,x,y,ADD_VALUES,SCATTER_FORWARD);
  VecScatterEnd(scat,x,y,ADD_VALUES,SCATTER_FORWARD);
  VecMin(y,&ymin);
  VecMax(y,&ymax);
If this is not satisfied, then there is no choice but to use the
implementation
  VecSet(y,0);
If ymin == 0, the index set is not surjective so the scatter is not a
"matrix" unless these entries (the left null space) are set to 0.  In
this case, we could store the indices of the zero entries in y and do
the scatter as
  VecScatterBegin(scat,x,y,INSERT_VALUES,SCATTER_FORWARD);
  VecGetArray(y,&yy);
  for (i=0; i<scat->to_nnullidx; i++) yy[scat->to_nullidx[i]] = 0;
  VecRestoreArray(y,&yy);
  VecScatterEnd(scat,x,y,INSERT_VALUES,SCATTER_FORWARD);
but this will only win if the number of such entries is small compared
to the size of y.  If the number of zero entries is large, then I don't
think we can beat
  VecSet(y,0);
We can do the same thing for the transpose.
So the question is, how much should we optimize this operation?  Is it
necessary to provide something like
  typedef enum {VECSCATTER_IS_INJECTIVE,VECSCATTER_IS_SURJECTIVE} VecScatterOption;
  PetscErrorCode VecScatterSetOption(VecScatter,Vec,Vec,ScatterMode,VecScatterOption,PetscTruth);
which would (analogous to ISSetPermutation()) test whether you are
telling the truth when in debug mode and believe you in optimized mode?
This seems excessive since it's fairly unlikely that the cost of the
VecSet(y,0), ADD_VALUES will be significant to applications.  Who is
using MATSCATTER anyway (the type name wasn't set prior to my commit
6d3d60abcf7d so it hasn't worked in a while)?
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090331/82fe64a5/attachment.sig>
