building PETSc on Windows
Lisandro Dalcin dalcinl at gmail.com
Mon Mar 23 11:09:44 CDT 2009
On Mon, Mar 23, 2009 at 11:48 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> 2) BuildSystem assumes that the shell is '/bin/sh'... I would need it
>> to find "sh" in the $PATH instead...
> Where is this assumption? In BuildSystem/config/programs.py we explicitly
> search for 'sh', so it is available, we just need to use it everywhere.
Check this file:
config/PETSc/utilities/petscdir.py
See the lines
      host   = config.base.Configure.executeShellCommand(self.shell+'
'+configGuess, log = self.framework.log)[0]
      output = config.base.Configure.executeShellCommand(self.shell+'
'+configSub+' '+host, log = self.framework.log)[0]
then see that 'self.shell' is naively defined to '/bin/sh' in
Script.__init__() in the file below
config/BuildSystem/script.py
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
