TS: high-order with Galerkin spatial discretization, semi-explicit index-1 DAE
Wed Mar 18 13:59:39 CDT 2009
I could not understand the post. We will have to go more slowly. To begin,
I cannot understand why you cannot use TSSetMatrices()
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/TS/TSSetMatrices.html#TSSetMatrices
     Matt
On Tue, Mar 17, 2009 at 9:15 PM, Jed Brown <jed at 59a2.org> wrote:
> I have a use for high-order implicit strong stability preserving
> integrators and plan to write a TS implementation based on some known
> optimal methods (cf. Gottlieb, Ketcheson, Shu 2009).  There are two
> cases of interest that I don't think TS can currently handle.
> Suppose we are using a Galerkin discretization so that the mass matrix
> is not the identity, but we still want to use high-order temporal
> discretization.  In particular, for high-order spatial discretizations,
> lumping the mass matrix is usually not acceptable so it would have dense
> inverse.  In these cases, MatShift is not sufficient [*].  One option is
> to allow shifts by an assembled mass matrix, but this is awkward with
> JFNK and requires significant storage when the mass matrix is not
> lumped.
> Perhaps a better option is for function evaluation and Jacobian assembly
> to observe the time-step (or a_{kk}*dt for Runge-Kutta methods).  This
> also works in the more general setting of semi-explicit index-1 DAE,
> presented in the form
>  V u_t = F(u,t)
> where F is the spatial discretization and V is typically block diagonal
> with mass matrices for differential variables and zero for algebraic
> variables.  To integrate such systems, the user would provide functions
> to evaluate
>  G(u,u_i,t,dt) = V u - F(dt*u+u_i,t)
> (u_i is a known inhomogeneous part) and assemble the
> Jacobian/preconditioner G'(u,t,dt).  This is sufficient for multistep
> and Diagonally Implicit Runge-Kutta (DIRK) methods.  For example, in the
> case of DIRK, stage k is computed by solving
>  G(u^k, u_0 + dt \sum_{l=0}^{k-1} a_{kl} u^l, t^k, dt a_{kk}) = 0
> for u^k.  For singly implicit Runge-Kutta (SIRK, a_{kk} constant)
> methods, lagging the preconditioner is perfectly acceptable since the
> time-step does not change frequently.  For JFNK with non-SIRK methods
> and with high-order multistep methods, the preconditioner would often
> have to be refactored to accommodate the shift, hence the inability to
> effectively lag the preconditioner is an unavoidable weakness.  Of
> course it is common that assembly is more expensive than PC setup in
> which case assembling F' and shifting by the mass matrix is appealing
> (assuming that storage for an assembled mass matrix is available).
> To summarize, asking the user to provide G,G' has the pros:
>  + consistent mass matrices with minimal cost
>  + DAE
>  + moving meshes
> and cons:
>  - not compatible with current F,F'
>  - shifts requiring reassembly are more expensive
> Asking the user to observe the time-step is at odds with the current
> interface where the user only provides F and F'.  Are the
> performance/flexibility benefits worth it?  How about a middle ground
> where the application can provide a lumped mass matrix (identity by
> default) and either functions F,F' or G,G' (where if G' is provided and
> the preconditioning matrix is different from the Jacobian, the
> preconditioner would be shifted using the lumped mass matrix)?
> I'd love to hear comments or suggestions.
> Jed
> [*] For my purposes, I don't actually need an assembled consistent mass
> matrix because my Jacobian is available via MatShell or MFFD (i.e. since
> shifting by the lumped mass matrix still produces a good preconditioner,
> the generalization of MatShift would be sufficient).  However, some
> people use the same matrix for the Jacobian and for preconditioning,
> hence a general scheme probably ought to be able to handle this.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090318/b8e57f5e/attachment.html>
