pull config/BuildSystem and rerun config/configure.py
Thu Jun 11 10:55:47 CDT 2009
On Jun 11, 2009, at 7:27 AM, Matthew Knepley wrote:
> Works now.
    What was wrong with it?
> However, the Scq options do not seem to be tested.
     Correct. You can add a test for them if you like, I couldn't be
bothered.
    Barry
>   Matt
> On Thu, Jun 11, 2009 at 6:51 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> Are there ever any tests of this shit? It broke IMMEDIATELY on my box.
>   Matt
> On Wed, Jun 10, 2009 at 11:02 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> On Wed, 10 Jun 2009, Barry Smith wrote:
> >   All petsc-dev users. Next time you pull petsc-dev make sure you
> pull
> > config/BuildSystem also and rerun your configure with
> > ${PETSC_ARCH}/conf/reconfigure-${PETSC_ARCH}.py
> > As always, report any problems to petsc-dev at mcs.anl.gov
> >   Barry
> > What I changed. I discovered the ar flags Sq that are much faster
> than our
> > current use of r. For my laptop these are the timings for "make
> all" debug
> > version
> >                regular libraries           --with-single-library(new
> > config/configure.py option to put all code into libpetsc.a (not
> yet working
> > for shared libraries)).
> > old           9 min 23 sec                    28 min
> > new         2 min 49 sec                      2 min 58 sec
> On linux [my laptop] - both the old and new mode [regular libraries]
> take about 2min10sec.
> > What I changed: added the flag FAST_AR_FLAGS that is used by
> libfast: instead
> > of AR_FLAGS; also added fast versions of buildmod called
> buildmodfast that use
> > libffast that uses FAST_AR_FLAGS
> > Once we get rid of the damn make we should see the entire "make
> all" take less
> > than a minute
> The issue is the recursive make - and all the shell processes that get
> created during it. If we have something eqivalent to automake - then
> it should zip through everything with 'make -j 8' - on the newer
> multicore machines pretty quickly..
> Satish
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
